| StarBear |
Aug 19 2022, 08:46 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,310 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States
A bit of a mystery about a set of four 1.8L injectors compared to known info. Known is VW/Bosch part 022906301C/0028150112, with spec of 18.1 lbs/hr or 190.2 cc/min. See top of pic (blue module).
This other set (bottom of pic gray module) has same VW number but has Bosch number 0028150102 (not 112); Mr Injector test results show 200 cc/min. Looks same as known. Can find no reference for a Bosch injector ending in 102. Questions: 1. Might the second set just be stamped wrong or are older, being superseded by 112? 2. Any undesirable or unwanted results from flow slightly higher than spec? Would it run rich? Way out of my wheelhouse here, so community experience and wisdom much appreciated! ![]() |
| Van B |
Aug 19 2022, 11:37 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,621 Joined: 20-October 21 From: WR, GA Member No.: 26,011 Region Association: None
These systems aren't measuring resulting mixture at all, hence no O2 sensors. So, it will inject fuel based on upstream inputs only; no down stream trimming.
Are you thinking about a mix and match set or running all 102 vs 112s? |
StarBear 1.8 Injectors Aug 19 2022, 08:46 AM
Van B Jeff's table is still the best reference tool ... Aug 19 2022, 08:55 AM
StarBear
Jeff's table is still the best reference tool... Aug 19 2022, 09:13 AM
StarBear
Jeff's table is still the best reference tool... Aug 19 2022, 09:21 AM
fiacra
Jeff's table is still the best reference tool... Aug 19 2022, 02:00 PM
StarBear
These systems aren't measuring resulting mixt... Aug 19 2022, 11:57 AM
Van B I guarantee you that your old injectors are not sp... Aug 19 2022, 12:30 PM
StarBear @ejm Ed; any insight or experience on this myste... Aug 19 2022, 01:19 PM
StarBear Bill “Mr. Injector” informs me that the two ar... Aug 19 2022, 01:27 PM
wonkipop from my trusty aus site
https://aussieinjectors.c... Aug 19 2022, 01:44 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th June 2026 - 05:10 AM |
