| NARP74 |
Aug 25 2022, 10:07 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I was fixing a pedal board issue, no hardware, wrong hardware, poor alignment, etc. Once I got all that worked out, I was going for a drive and the clutch was barely engaging. Made for a tough drive. 1st and Rev were grinding and the others were not much better.
I did find a list of things to check for issues like this and I am going through those. I also saw the Dr Evil drawing for clutch engagement. Mine seems to engage just off the pedal stop now. Is there a real spec for clutch adjustment or is it just by feel? How could this be related to the pedal board? It was fine before I moved it around. |
| NARP74 |
Aug 25 2022, 05:33 PM
I agree, I just don't know what changed since the only thing I messed with was the pedal board.
NARP74 Pedal Board Adjustment Aug 25 2022, 10:07 AM
BeatNavy Just a swag, but maybe in the process of adjusting... Aug 25 2022, 10:10 AM
NARP74
Just a swag, but maybe in the process of adjustin... Aug 25 2022, 10:27 AM
NARP74 Is it possible for this adjustment to be correct a... Aug 25 2022, 03:50 PM
mgphoto
Is it possible for this adjustment to be correct ... Aug 25 2022, 05:26 PM
BeatNavy
Is it possible for this adjustment to be correct... Aug 25 2022, 05:29 PM
JamesM
I agree, I just don't know what changed since... Aug 25 2022, 06:56 PM
NARP74 I tightened one side of the pedal stop that was lo... Aug 25 2022, 07:36 PM
JamesM
I tightened one side of the pedal stop that was l... Aug 25 2022, 07:45 PM
NARP74 The plot thickens... I am missing the stop plate w... Aug 25 2022, 08:54 PM
JamesM
The plot thickens... I am missing the stop plate ... Aug 25 2022, 09:13 PM
NARP74 How do you install this washer?
https://914rubber.... Aug 25 2022, 09:52 PM
BeatNavy
https://914rubber... Aug 26 2022, 05:09 AM
targa72e Your clutch cable is not engaged properly. The cab... Aug 25 2022, 10:59 PM
ClayPerrine We always called that washer a "Beer Tab... Aug 26 2022, 07:54 AM
NARP74 Thanks all. The cable was in the U shaped slot be... Aug 26 2022, 08:42 AM
ClayPerrine
All's well that ends well. I was thinking of... Aug 26 2022, 11:58 AM
jfort when the cable is in its housing, safety wire it i... Aug 26 2022, 12:55 PM
NARP74 Got the repair parts, thanks Mikey. Took it all a... Sep 3 2022, 05:03 PM
BeatNavy :trophy:
Everything I touch is a learning process... Sep 3 2022, 06:34 PM![]() ![]() |
Lo-Fi Version | Time is now: 28th October 2026 - 12:14 AM |
