> Pedal Board Adjustment, What Did I Do?
NARP74
post Aug 25 2022, 10:07 AM
I was fixing a pedal board issue, no hardware, wrong hardware, poor alignment, etc. Once I got all that worked out, I was going for a drive and the clutch was barely engaging. Made for a tough drive. 1st and Rev were grinding and the others were not much better.
I did find a list of things to check for issues like this and I am going through those.
I also saw the Dr Evil drawing for clutch engagement. Mine seems to engage just off the pedal stop now. Is there a real spec for clutch adjustment or is it just by feel?
How could this be related to the pedal board? It was fine before I moved it around.
NARP74
post Aug 25 2022, 07:36 PM
I tightened one side of the pedal stop that was loose, the washer was rattling. I leveled it out and tightened it. I guess that could have taken up any travel that it needed. But if that is the case the clutch is not adjusted correctly. The pedal stop might have been at an angle as the one side that was loose slid up to the top of the board. it is almost all the way at the top of the board. Not sure where it is supposed to be.
JamesM
post Aug 25 2022, 07:45 PM
QUOTE(NARP74 @ Aug 25 2022, 05:36 PM) *
By the look of the nuts on your cable I would agree your clutch probably isn't adjusted correctly.
Tighten the cable so the clutch pedal goes "over center" in the first 1/3 of pedal travel. then adjust the pedal stop to keep the clutch fork from hitting the tranny case when fully engaged.
Also worth noting, every single one of my 914s I had to add a shim to the clutch fork pivot ball to get proper clutch feel. I suspect most flywheels out there have been machined to the point where they would benefit from a re-shimming of the clutch fork.
NARP74   Pedal Board Adjustment   Aug 25 2022, 10:07 AM
BeatNavy   Just a swag, but maybe in the process of adjusting...   Aug 25 2022, 10:10 AM
NARP74   Just a swag, but maybe in the process of adjustin...   Aug 25 2022, 10:27 AM
NARP74   Is it possible for this adjustment to be correct a...   Aug 25 2022, 03:50 PM
mgphoto   Is it possible for this adjustment to be correct ...   Aug 25 2022, 05:26 PM
BeatNavy   Is it possible for this adjustment to be correct...   Aug 25 2022, 05:29 PM
NARP74   I agree, I just don't know what changed since ...   Aug 25 2022, 05:33 PM
JamesM   I agree, I just don't know what changed since...   Aug 25 2022, 06:56 PM
NARP74   I tightened one side of the pedal stop that was lo...   Aug 25 2022, 07:36 PM
JamesM   I tightened one side of the pedal stop that was l...   Aug 25 2022, 07:45 PM
NARP74   The plot thickens... I am missing the stop plate w...   Aug 25 2022, 08:54 PM
JamesM   The plot thickens... I am missing the stop plate ...   Aug 25 2022, 09:13 PM
NARP74   How do you install this washer? https://914rubber....   Aug 25 2022, 09:52 PM
BeatNavy   How do you install this washer? https://914rubber...   Aug 26 2022, 05:09 AM
targa72e   Your clutch cable is not engaged properly. The cab...   Aug 25 2022, 10:59 PM
ClayPerrine   We always called that washer a "Beer Tab...   Aug 26 2022, 07:54 AM
NARP74   Thanks all. The cable was in the U shaped slot be...   Aug 26 2022, 08:42 AM
ClayPerrine   All's well that ends well. I was thinking of...   Aug 26 2022, 11:58 AM
jfort   when the cable is in its housing, safety wire it i...   Aug 26 2022, 12:55 PM
NARP74   Got the repair parts, thanks Mikey. Took it all a...   Sep 3 2022, 05:03 PM
BeatNavy   :trophy: Everything I touch is a learning process...   Sep 3 2022, 06:34 PM
- Lo-Fi Version Time is now: 28th October 2026 - 12:14 AM
