> Pedal Board Adjustment, What Did I Do?
NARP74
post Aug 25 2022, 10:07 AM
I was fixing a pedal board issue, no hardware, wrong hardware, poor alignment, etc. Once I got all that worked out, I was going for a drive and the clutch was barely engaging. Made for a tough drive. 1st and Rev were grinding and the others were not much better.
I did find a list of things to check for issues like this and I am going through those.
I also saw the Dr Evil drawing for clutch engagement. Mine seems to engage just off the pedal stop now. Is there a real spec for clutch adjustment or is it just by feel?
How could this be related to the pedal board? It was fine before I moved it around.
NARP74
post Aug 25 2022, 09:52 PM
How do you install this washer?
https://914rubber.com/clutch-cable-stop-pla...for-porsche-914
NARP74   Pedal Board Adjustment   Aug 25 2022, 10:07 AM
BeatNavy   Just a swag, but maybe in the process of adjusting...   Aug 25 2022, 10:10 AM
NARP74   Just a swag, but maybe in the process of adjustin...   Aug 25 2022, 10:27 AM
NARP74   Is it possible for this adjustment to be correct a...   Aug 25 2022, 03:50 PM
mgphoto   Is it possible for this adjustment to be correct ...   Aug 25 2022, 05:26 PM
BeatNavy   Is it possible for this adjustment to be correct...   Aug 25 2022, 05:29 PM
NARP74   I agree, I just don't know what changed since ...   Aug 25 2022, 05:33 PM
JamesM   I agree, I just don't know what changed since...   Aug 25 2022, 06:56 PM
NARP74   I tightened one side of the pedal stop that was lo...   Aug 25 2022, 07:36 PM
JamesM   I tightened one side of the pedal stop that was l...   Aug 25 2022, 07:45 PM
NARP74   The plot thickens... I am missing the stop plate w...   Aug 25 2022, 08:54 PM
JamesM   The plot thickens... I am missing the stop plate ...   Aug 25 2022, 09:13 PM
NARP74   How do you install this washer? https://914rubber....   Aug 25 2022, 09:52 PM
BeatNavy   How do you install this washer? https://914rubber...   Aug 26 2022, 05:09 AM
targa72e   Your clutch cable is not engaged properly. The cab...   Aug 25 2022, 10:59 PM
ClayPerrine   We always called that washer a "Beer Tab...   Aug 26 2022, 07:54 AM
NARP74   Thanks all. The cable was in the U shaped slot be...   Aug 26 2022, 08:42 AM
ClayPerrine   All's well that ends well. I was thinking of...   Aug 26 2022, 11:58 AM
jfort   when the cable is in its housing, safety wire it i...   Aug 26 2022, 12:55 PM
NARP74   Got the repair parts, thanks Mikey. Took it all a...   Sep 3 2022, 05:03 PM
BeatNavy   :trophy: Everything I touch is a learning process...   Sep 3 2022, 06:34 PM
- Lo-Fi Version Time is now: 28th October 2026 - 12:14 AM
