| NARP74 |
Aug 25 2022, 10:07 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I was fixing a pedal board issue, no hardware, wrong hardware, poor alignment, etc. Once I got all that worked out, I was going for a drive and the clutch was barely engaging. Made for a tough drive. 1st and Rev were grinding and the others were not much better.
I did find a list of things to check for issues like this and I am going through those. I also saw the Dr Evil drawing for clutch engagement. Mine seems to engage just off the pedal stop now. Is there a real spec for clutch adjustment or is it just by feel? How could this be related to the pedal board? It was fine before I moved it around. |
| targa72e |
Aug 25 2022, 10:59 PM
Member ![]() ![]() Group: Members Posts: 307 Joined: 11-September 16 From: colorado Member No.: 20,392 Region Association: None
Your clutch cable is not engaged properly. The cable should be in the slot at the point of the arrow in pic. None of my cars have had that washer listed by others but seems like a good idea. One car I purchased had some wire to hold the cable in place. I will probably add the washer as it seems like a good idea but has not been a problem yet.
Having just adjusted my clutch tonight. Adjust the cable at the tranny end until you get to the point that you can just put it in reverse with out grinding. john |
NARP74 Pedal Board Adjustment Aug 25 2022, 10:07 AM
BeatNavy Just a swag, but maybe in the process of adjusting... Aug 25 2022, 10:10 AM
NARP74
Just a swag, but maybe in the process of adjustin... Aug 25 2022, 10:27 AM
NARP74 Is it possible for this adjustment to be correct a... Aug 25 2022, 03:50 PM
mgphoto
Is it possible for this adjustment to be correct ... Aug 25 2022, 05:26 PM
BeatNavy
Is it possible for this adjustment to be correct... Aug 25 2022, 05:29 PM
NARP74 I agree, I just don't know what changed since ... Aug 25 2022, 05:33 PM
JamesM
I agree, I just don't know what changed since... Aug 25 2022, 06:56 PM
NARP74 I tightened one side of the pedal stop that was lo... Aug 25 2022, 07:36 PM
JamesM
I tightened one side of the pedal stop that was l... Aug 25 2022, 07:45 PM
NARP74 The plot thickens... I am missing the stop plate w... Aug 25 2022, 08:54 PM
JamesM
The plot thickens... I am missing the stop plate ... Aug 25 2022, 09:13 PM
NARP74 How do you install this washer?
https://914rubber.... Aug 25 2022, 09:52 PM
BeatNavy
https://914rubber... Aug 26 2022, 05:09 AM
ClayPerrine We always called that washer a "Beer Tab... Aug 26 2022, 07:54 AM
NARP74 Thanks all. The cable was in the U shaped slot be... Aug 26 2022, 08:42 AM
ClayPerrine
All's well that ends well. I was thinking of... Aug 26 2022, 11:58 AM
jfort when the cable is in its housing, safety wire it i... Aug 26 2022, 12:55 PM
NARP74 Got the repair parts, thanks Mikey. Took it all a... Sep 3 2022, 05:03 PM
BeatNavy :trophy:
Everything I touch is a learning process... Sep 3 2022, 06:34 PM![]() ![]() |
Lo-Fi Version | Time is now: 28th October 2026 - 12:15 AM |
