| NARP74 |
Aug 25 2022, 10:07 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I was fixing a pedal board issue, no hardware, wrong hardware, poor alignment, etc. Once I got all that worked out, I was going for a drive and the clutch was barely engaging. Made for a tough drive. 1st and Rev were grinding and the others were not much better.
I did find a list of things to check for issues like this and I am going through those. I also saw the Dr Evil drawing for clutch engagement. Mine seems to engage just off the pedal stop now. Is there a real spec for clutch adjustment or is it just by feel? How could this be related to the pedal board? It was fine before I moved it around. |
| NARP74 |
Aug 25 2022, 09:52 PM
| BeatNavy |
Aug 26 2022, 05:09 AM
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,967 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region
The cable goes through that washer and the "pointy" end is inserted through that square hole you see in your picture (center, above the M8 nut) and bent around to keep it in place. It's needed. Your picture explains a lot of what's going on now! |
NARP74 Pedal Board Adjustment Aug 25 2022, 10:07 AM
BeatNavy Just a swag, but maybe in the process of adjusting... Aug 25 2022, 10:10 AM
NARP74
Just a swag, but maybe in the process of adjustin... Aug 25 2022, 10:27 AM
NARP74 Is it possible for this adjustment to be correct a... Aug 25 2022, 03:50 PM
mgphoto
Is it possible for this adjustment to be correct ... Aug 25 2022, 05:26 PM
BeatNavy
Is it possible for this adjustment to be correct... Aug 25 2022, 05:29 PM
NARP74 I agree, I just don't know what changed since ... Aug 25 2022, 05:33 PM
JamesM
I agree, I just don't know what changed since... Aug 25 2022, 06:56 PM
NARP74 I tightened one side of the pedal stop that was lo... Aug 25 2022, 07:36 PM
JamesM
I tightened one side of the pedal stop that was l... Aug 25 2022, 07:45 PM
NARP74 The plot thickens... I am missing the stop plate w... Aug 25 2022, 08:54 PM
JamesM
The plot thickens... I am missing the stop plate ... Aug 25 2022, 09:13 PM
targa72e Your clutch cable is not engaged properly. The cab... Aug 25 2022, 10:59 PM
ClayPerrine We always called that washer a "Beer Tab... Aug 26 2022, 07:54 AM
NARP74 Thanks all. The cable was in the U shaped slot be... Aug 26 2022, 08:42 AM
ClayPerrine
All's well that ends well. I was thinking of... Aug 26 2022, 11:58 AM
jfort when the cable is in its housing, safety wire it i... Aug 26 2022, 12:55 PM
NARP74 Got the repair parts, thanks Mikey. Took it all a... Sep 3 2022, 05:03 PM
BeatNavy :trophy:
Everything I touch is a learning process... Sep 3 2022, 06:34 PM![]() ![]() |
Lo-Fi Version | Time is now: 28th October 2026 - 12:14 AM |
