> Pedal Board Adjustment, What Did I Do?
NARP74
post Aug 25 2022, 10:07 AM
I was fixing a pedal board issue, no hardware, wrong hardware, poor alignment, etc. Once I got all that worked out, I was going for a drive and the clutch was barely engaging. Made for a tough drive. 1st and Rev were grinding and the others were not much better.
I did find a list of things to check for issues like this and I am going through those.
I also saw the Dr Evil drawing for clutch engagement. Mine seems to engage just off the pedal stop now. Is there a real spec for clutch adjustment or is it just by feel?
How could this be related to the pedal board? It was fine before I moved it around.
NARP74
post Aug 26 2022, 08:42 AM
Thanks all. The cable was in the U shaped slot before I started pulling on it. I don' think it would shift at all if it wasn't. The pic I took was after I pulled on it and it popped right out without the beer can washer installed. Shows how much slack was in the line. Seems like a series of small events that lead to the clutch not performing properly.
All's well that ends well. I was thinking of driving this to the RRC but I have not had it long enough to work out the bugs yet. Getting some parts on order from Mikey today. Yet another learning opportunity in 914 World.
ClayPerrine
post Aug 26 2022, 11:58 AM
QUOTE(NARP74 @ Aug 26 2022, 09:42 AM) *
Do it! Just drive it to SLC. We are coming with a truck and trailer, so if it breaks, we can get you home. We have to go through Colorado to get back to Texas anyway.
NARP74   Pedal Board Adjustment   Aug 25 2022, 10:07 AM
BeatNavy   Just a swag, but maybe in the process of adjusting...   Aug 25 2022, 10:10 AM
NARP74   Just a swag, but maybe in the process of adjustin...   Aug 25 2022, 10:27 AM
NARP74   Is it possible for this adjustment to be correct a...   Aug 25 2022, 03:50 PM
mgphoto   Is it possible for this adjustment to be correct ...   Aug 25 2022, 05:26 PM
BeatNavy   Is it possible for this adjustment to be correct...   Aug 25 2022, 05:29 PM
NARP74   I agree, I just don't know what changed since ...   Aug 25 2022, 05:33 PM
JamesM   I agree, I just don't know what changed since...   Aug 25 2022, 06:56 PM
NARP74   I tightened one side of the pedal stop that was lo...   Aug 25 2022, 07:36 PM
JamesM   I tightened one side of the pedal stop that was l...   Aug 25 2022, 07:45 PM
NARP74   The plot thickens... I am missing the stop plate w...   Aug 25 2022, 08:54 PM
JamesM   The plot thickens... I am missing the stop plate ...   Aug 25 2022, 09:13 PM
NARP74   How do you install this washer? https://914rubber....   Aug 25 2022, 09:52 PM
BeatNavy   How do you install this washer? https://914rubber...   Aug 26 2022, 05:09 AM
targa72e   Your clutch cable is not engaged properly. The cab...   Aug 25 2022, 10:59 PM
ClayPerrine   We always called that washer a "Beer Tab...   Aug 26 2022, 07:54 AM
NARP74   Thanks all. The cable was in the U shaped slot be...   Aug 26 2022, 08:42 AM
ClayPerrine   All's well that ends well. I was thinking of...   Aug 26 2022, 11:58 AM
jfort   when the cable is in its housing, safety wire it i...   Aug 26 2022, 12:55 PM
NARP74   Got the repair parts, thanks Mikey. Took it all a...   Sep 3 2022, 05:03 PM
BeatNavy   :trophy: Everything I touch is a learning process...   Sep 3 2022, 06:34 PM
- Lo-Fi Version Time is now: 28th October 2026 - 12:15 AM
