> Front Recovery Tow Point, Jman Option
jdamiano
post Sep 4 2022, 06:16 PM
My car has dealership installed AC so the front tow point is gone. I got it with a bent drop link I’m sure was the result of a past tow. I’m trying to figure out what my options are and found these tie downs from Jman. Has anyone used these or something similar? If so I would really appreciate a picture of one installed.
AzGuy238
post Sep 5 2022, 11:44 AM
I actually reversed them and only use the two bolt holes on the side...use Grade 8 bolts.Attached Image Attached ImageAttached ImageAttached Image[attachmentid=850
315]
jdamiano   Front Recovery Tow Point   Sep 4 2022, 06:16 PM
mlindner   Yes, those are 911 type and will fit. But, not wit...   Sep 5 2022, 06:19 AM
AzGuy238   I have them on my 1976 and they seem to work fine ...   Sep 5 2022, 06:25 AM
jdamiano   I have them on my 1976 and they seem to work fine...   Sep 5 2022, 07:05 AM
TX914   I have a similar situation and looked into a tow l...   Sep 5 2022, 06:34 AM
infraredcalvin   My car has dealership installed AC so the front t...   Sep 5 2022, 11:15 AM
AzGuy238   I actually reversed them and only use the two bolt...   Sep 5 2022, 11:44 AM
jdamiano   I actually reversed them and only use the two bol...   Sep 5 2022, 12:06 PM
AzGuy238   sorry, I'm not very good at posting photos   Sep 5 2022, 11:58 AM
Superhawk996   Duplicate   Sep 5 2022, 01:05 PM
Superhawk996   By turning those around and eliminating the 3rd fa...   Sep 5 2022, 01:07 PM
jdamiano   By turning those around and eliminating the 3rd f...   Sep 5 2022, 01:27 PM
jdamiano   Here is how I ended up mounting the Jman loop.   Sep 17 2022, 04:40 PM
ChrisFoley   It really shouldn't be between the a-arm carri...   Sep 17 2022, 05:55 PM
jdamiano   It really shouldn't be between the a-arm carr...   Sep 17 2022, 07:16 PM
Superhawk996   It really shouldn't be between the a-arm car...   Sep 17 2022, 08:03 PM
914werke   Confused about intended use? Title says "Tow ...   Sep 18 2022, 07:54 AM
jdamiano   Confused about intended use? Title says "Tow...   Sep 18 2022, 08:24 AM
ChrisFoley   I’m trying to add a good place to hook a tow c...   Sep 18 2022, 08:42 AM
robkammer   I’m trying to add a good place to hook a tow ...   Sep 26 2022, 04:39 PM
Olympic 914   I carry a couple motorcycle tie down straps. Wrap...   Sep 18 2022, 08:41 AM
mepstein   I carry a couple motorcycle tie down straps. Wra...   Sep 25 2022, 07:52 AM
jdamiano   Here is the way I ended up installing it. Had to m...   Sep 24 2022, 03:23 PM
ChrisFoley   Here is the way I ended up installing it. Had to ...   Dec 19 2022, 04:43 AM
ChrisFoley   That looks ok as an emergency tow point - as usefu...   Sep 25 2022, 03:53 AM
930cabman   Why would you need a front tow point?   Sep 25 2022, 08:06 AM
jdamiano   Why would you need a front tow point? The recov...   Sep 25 2022, 09:37 AM
930cabman   Why would you need a front tow point? The reco...   Sep 25 2022, 05:42 PM
ChrisFoley   RE: Front Recovery Tow Point   Dec 19 2022, 05:02 AM
- Lo-Fi Version Time is now: 3rd October 2026 - 12:06 AM
