| jdamiano |
Sep 4 2022, 06:16 PM
Member ![]() ![]() Group: Members Posts: 336 Joined: 18-March 18 From: Jacksonville Member No.: 21,981 Region Association: South East States |
My car has dealership installed AC so the front tow point is gone. I got it with a bent drop link I’m sure was the result of a past tow. I’m trying to figure out what my options are and found these tie downs from Jman. Has anyone used these or something similar? If so I would really appreciate a picture of one installed.
| Superhawk996 |
Sep 5 2022, 01:07 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,104 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
By turning those around and eliminating the 3rd fastener you are likey going to find that they fold up when you need them.
Two fasteners creates a hinge point where they will bend when loaded. Also front suspension fasteners should be Grade 10.9 not 8.8. Metric grade 8.8 is basically equivalent to SAE grade 5. |
| jdamiano |
Sep 5 2022, 01:27 PM
By turning those around and eliminating the 3rd fastener you are likey going to find that they fold up when you need them. Two fasteners creates a hinge point where they will bend when loaded. Also front suspension fasteners should be Grade 10.9 not 8.8. Metric grade 8.8 is basically equivalent to SAE grade 5. If it fold great. Maybe it will create more clearance causing less chance of damage to the valance. I might also gusset it on the sides. Never work on my baja bug since it gets pulled hard sometimes. I had it up to the doors in mud a few months ago and it got snatched hard. Hopefully I never need this and if I do it’s a slow pull onto a flatbed. I’m also going to add a soft shackle to my trunk supply to go from this to any cable the tow guy wants to use. I will take your advice on the bolts though. Thanks. |
jdamiano Front Recovery Tow Point Sep 4 2022, 06:16 PM
mlindner Yes, those are 911 type and will fit. But, not wit... Sep 5 2022, 06:19 AM
AzGuy238 I have them on my 1976 and they seem to work fine ... Sep 5 2022, 06:25 AM
jdamiano
I have them on my 1976 and they seem to work fine... Sep 5 2022, 07:05 AM
TX914 I have a similar situation and looked into a tow l... Sep 5 2022, 06:34 AM
infraredcalvin
My car has dealership installed AC so the front t... Sep 5 2022, 11:15 AM
AzGuy238 I actually reversed them and only use the two bolt... Sep 5 2022, 11:44 AM
jdamiano
I actually reversed them and only use the two bol... Sep 5 2022, 12:06 PM
AzGuy238 sorry, I'm not very good at posting photos Sep 5 2022, 11:58 AM
Superhawk996 Duplicate Sep 5 2022, 01:05 PM
jdamiano Here is how I ended up mounting the Jman loop. Sep 17 2022, 04:40 PM
ChrisFoley It really shouldn't be between the a-arm carri... Sep 17 2022, 05:55 PM
jdamiano
It really shouldn't be between the a-arm carr... Sep 17 2022, 07:16 PM
Superhawk996
It really shouldn't be between the a-arm car... Sep 17 2022, 08:03 PM
914werke Confused about intended use? Title says "Tow ... Sep 18 2022, 07:54 AM
jdamiano
Confused about intended use? Title says "Tow... Sep 18 2022, 08:24 AM
ChrisFoley
I’m trying to add a good place to hook a tow c... Sep 18 2022, 08:42 AM
robkammer
I’m trying to add a good place to hook a tow ... Sep 26 2022, 04:39 PM
Olympic 914 I carry a couple motorcycle tie down straps.
Wrap... Sep 18 2022, 08:41 AM
Wra... Sep 25 2022, 07:52 AM
jdamiano Here is the way I ended up installing it. Had to m... Sep 24 2022, 03:23 PM
ChrisFoley
Here is the way I ended up installing it. Had to ... Dec 19 2022, 04:43 AM
ChrisFoley That looks ok as an emergency tow point - as usefu... Sep 25 2022, 03:53 AM
930cabman Why would you need a front tow point? Sep 25 2022, 08:06 AM
jdamiano
The recov... Sep 25 2022, 09:37 AM
930cabman
The reco... Sep 25 2022, 05:42 PM
ChrisFoley RE: Front Recovery Tow Point Dec 19 2022, 05:02 AM![]() ![]() |
Lo-Fi Version | Time is now: 3rd October 2026 - 12:05 AM |
