pfreiburger |
Member ![]() ![]() Group: Members Posts: 127 Joined: 6-October 20 From: Fond du Lac, WI Member No.: 24,738 Region Association: None ![]() ![]() |
I am now quite certain that the factory did install some black door handles. I came to this determination in a roundabout (and expensive) way, starting when my inner hammer mechanic escaped and broke the driver door handle.
As no black ones exist, I picked up a new chrome (Sierra Madre) handle and was surprised to find that my old lock cylinder (after removing the black paint) would not fit the chrome handle. The length was fine, but it fit so tight it could not be turned. At all. Measuring the ID of the handle bores confirmed that the black handle was larger, even with paint on it. The used chrome-handle lock cylinder I bought on line later fit and turned in the new chrome handle just fine. And that used chrome handle cylinder definitely had more clearance when inserted in the old black handle. Measuring the cap ends of the lock cylinder confirmed it – the cylinder from the black handle was larger in diameter. Dissimilar sized handle components are almost certainly no customizer job, and damn sure no hot rod job. The only conclusion I can draw is that Porsche had a supplier make a run of black handles, and for whatever reason some components were made a little different. This fits with what I found when I scraped some black paint from the broken handle: no evidence of chrome ever being applied to the casting. Lastly, there are factory pictures (albeit poor ones) of black A pillar cars that look like they have black handles also. Am I missing another explanation? |
wonkipop |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,822 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille ![]() ![]() |
the red VW museum car seems to maybe be in a fluid state of trim over recent images.
was on display at 50th in porsche museum. trim around windscreen and door handles def. chrome. ![]() back in 2014/15 it looks like it might have been black, but could also just be lighting, black surfaced ceiling making reflections in chrome look black. door handles look like they are chrome. if the photos are to be trusted, its been chrome, then black, then chrome again. or its just always been chrome and some of the images make it look black. ![]() ![]() |
PCH |
Member ![]() ![]() Group: Members Posts: 146 Joined: 3-January 19 From: Santa Barbara Member No.: 22,772 Region Association: Southern California ![]() ![]() |
Interesting that the VW factory museum 914 carries a Porsche hood badge.
wonkipop |
Interesting that the VW factory museum 914 carries a Porsche hood badge. think that car got tarted/"restored" somewhere along the way over the years. older photos of what looks to have been the same car in VW collection show it without a badge. they also changed the wheels on it. didn't even get those right if you look close, they are actually VW sport wheels, you can tell by the offset and the little hexagonal plastic hub centres that were made to look like bolts (fake). the post 74 914 steelies had a slightly different offset and you can spot the difference. i dunno exactly what happened but it must have been given a freshen up for some event back in the mists of time and someone decided to bring it up to date? or they dragged it out of a dusty corner where it had been lying and did a "restoration" before they put it on permanent public display. |
Lo-Fi Version | Time is now: 16th July 2025 - 03:36 AM |
