> Front Recovery Tow Point, Jman Option
jdamiano
post Sep 4 2022, 06:16 PM
My car has dealership installed AC so the front tow point is gone. I got it with a bent drop link I’m sure was the result of a past tow. I’m trying to figure out what my options are and found these tie downs from Jman. Has anyone used these or something similar? If so I would really appreciate a picture of one installed.
914werke
post Sep 18 2022, 07:54 AM
Confused about intended use? Title says "Tow point" are those actually intended to tow with ? I thought they are more focused as a
Recovery point.
Agree with previous comments, you really need that front bolt as it's the only that penetrates & is seam welded to the tub, & for fitment you have to remove the covers.
jdamiano
post Sep 18 2022, 08:24 AM
QUOTE(914werke @ Sep 18 2022, 07:54 AM) *
Recovery point.
Agree with previous comments, you really need that front bolt as it's the only that penetrates & is seam welded to the tub & for fitment you have to remove the covers.
I’m trying to add a good place to hook a tow cable to in case I need to drag it up my trailer or a tow truck. I haven’t found one 914 specific that doesn’t stick out the front. This one was listed for a 914 but that front bolt no way matches the location on a 914. Also if I install it with the third bolt hole facing forward I can’t reinstall the torsion bar protector. Right now I’m thinking I’m going to keep it pointing the same way but move it below the mount bracket. The loop on this one is closer to the two bolts and shorter than the ones posted earlier in this thread so I think it will be strong enough. If someone has a better solution I’m all ears!
jdamiano   Front Recovery Tow Point   Sep 4 2022, 06:16 PM
mlindner   Yes, those are 911 type and will fit. But, not wit...   Sep 5 2022, 06:19 AM
AzGuy238   I have them on my 1976 and they seem to work fine ...   Sep 5 2022, 06:25 AM
jdamiano   I have them on my 1976 and they seem to work fine...   Sep 5 2022, 07:05 AM
TX914   I have a similar situation and looked into a tow l...   Sep 5 2022, 06:34 AM
infraredcalvin   My car has dealership installed AC so the front t...   Sep 5 2022, 11:15 AM
AzGuy238   I actually reversed them and only use the two bolt...   Sep 5 2022, 11:44 AM
jdamiano   I actually reversed them and only use the two bol...   Sep 5 2022, 12:06 PM
AzGuy238   sorry, I'm not very good at posting photos   Sep 5 2022, 11:58 AM
Superhawk996   Duplicate   Sep 5 2022, 01:05 PM
Superhawk996   By turning those around and eliminating the 3rd fa...   Sep 5 2022, 01:07 PM
jdamiano   By turning those around and eliminating the 3rd f...   Sep 5 2022, 01:27 PM
jdamiano   Here is how I ended up mounting the Jman loop.   Sep 17 2022, 04:40 PM
ChrisFoley   It really shouldn't be between the a-arm carri...   Sep 17 2022, 05:55 PM
jdamiano   It really shouldn't be between the a-arm carr...   Sep 17 2022, 07:16 PM
Superhawk996   It really shouldn't be between the a-arm car...   Sep 17 2022, 08:03 PM
914werke   Confused about intended use? Title says "Tow ...   Sep 18 2022, 07:54 AM
jdamiano   Confused about intended use? Title says "Tow...   Sep 18 2022, 08:24 AM
ChrisFoley   I’m trying to add a good place to hook a tow c...   Sep 18 2022, 08:42 AM
robkammer   I’m trying to add a good place to hook a tow ...   Sep 26 2022, 04:39 PM
Olympic 914   I carry a couple motorcycle tie down straps. Wrap...   Sep 18 2022, 08:41 AM
mepstein   I carry a couple motorcycle tie down straps. Wra...   Sep 25 2022, 07:52 AM
jdamiano   Here is the way I ended up installing it. Had to m...   Sep 24 2022, 03:23 PM
ChrisFoley   Here is the way I ended up installing it. Had to ...   Dec 19 2022, 04:43 AM
ChrisFoley   That looks ok as an emergency tow point - as usefu...   Sep 25 2022, 03:53 AM
930cabman   Why would you need a front tow point?   Sep 25 2022, 08:06 AM
jdamiano   Why would you need a front tow point? The recov...   Sep 25 2022, 09:37 AM
930cabman   Why would you need a front tow point? The reco...   Sep 25 2022, 05:42 PM
ChrisFoley   RE: Front Recovery Tow Point   Dec 19 2022, 05:02 AM
- Lo-Fi Version Time is now: 3rd October 2026 - 12:05 AM
