> Plan of Action?, Bondo Floor?
stoneman30hotmail
post Sep 10 2022, 05:07 PM
Hello all, I'm a bit new to this. I had one of these in my 20's and and did a little stick welding fixing the hell hole.
I'm not sure how to approach this. Do I need to strip all this and go on rotisserie? Or is it feasible to cut and patch this from the top
The driver side floor is bondo (or something). I'm not sure what is holding the seat mounts. The passenger side seat mount right is about broken loose. There's also holes past the transverse strut into the battery area.
The longs seem ok from what I can see. Can I get the sill covers off without taking the fenders off? I was worried I drill out all the rivets to figure one hidden under the fender.
Any good tool recommendations for rust removal?
I was thinking maybe I can get away with with https://www.restoration-design.com/store/product/PP345BR and a https://www.restoration-design.com/store/PR...duct_Code=PP325 and the seat brakets and patch the holes.
Attached Image Attached Image Attached ImageAttached Image
stoneman30hotmail
post Sep 18 2022, 05:47 PM
Wow guys, thanks for all the attention and references. A common theme looks to be to strip the car, put it on a frame and remove a lot of body panels. A few of the cars didn't look as bad as mine. So, I'm starting to come out of denial. I'm a bit nervous about exterior body work, but maybe if I work for the inside out, I'll have some skills by then.
I tend to be a finisher of projects. My steam hours say I have time to divert from video games. I don't do the mindless ones either. But I'm also frugal. I've been telling myself that video games are cheaper than project cars. But I couldn't resist the low cost of entry into this. I hope that the car will be worth more than the sum of the parts (and tools?). I do want to retire soon...
Ok so enough introductions. Here's some photos after playing with the new grinder and attachments:
So do we say all this pitted stuff is bad stuff? Looks like it has been coated in rust converter a while back.
I guess the floor just has to come totally out.
I've seen pictures where there is an inside piece towards outside but there looks to be a piece inside towards the inside.
I guess I need a better support strategy before cutting? I saw someone argue against a rotisserie when the car needs structural repair. So has someone made the octagon rotisserie with structural support?
nathanxnathan
post Sep 19 2022, 02:10 PM
QUOTE(stoneman30hotmail @ Sep 18 2022, 04:47 PM) *
That looks scary as hell. You are in for a real education tackling that.
You need a lower firewall inner and outer, inner fender well (usually comes with the inner part of the outer long attached), only the inner part of the inner long is available and people just run that without the outer part of the inner. You'll probably need a jack cover plate, the lower jack plate, possibly an inner suspension console, and may have to replace the outer suspension console which isn't available except from a donor. Also floors. It's not going to be cheap or easy, you're going to need a lot of tools, and it's going to take a lot of work/time.
There's a quote, something like "a cheap 914 is the most expensive one you can get". Seriously you may want to look for one in better shape.
bbrock
post Sep 19 2022, 05:27 PM
QUOTE(nathanxnathan @ Sep 19 2022, 02:10 PM) *
This is a really important point. If you are eager for a project and a challenge where the sense of accomplishment is the reward, this is a great car. If you just want to patch something together so you can drive it, this car is not your friend. There are cheaper and easier ways to get into a driver.
stoneman30hotmail   Plan of Action?   Sep 10 2022, 05:07 PM
Superhawk996   Read these before you do anything. You have more ...   Sep 10 2022, 05:21 PM
SirAndy   You have more project on your hands than you think...   Sep 10 2022, 05:57 PM
bbrock   You have more project on your hands than you thin...   Sep 10 2022, 10:30 PM
Mikey914   If you choose to do this sure you have a brace in ...   Sep 10 2022, 06:10 PM
930cabman   Welcome aboard and it looks as though you are jump...   Sep 10 2022, 06:32 PM
mepstein   :wttc: The rust you see is always the tip of the ...   Sep 10 2022, 07:53 PM
bkrantz   Jump (gently) up and down on the right side and wa...   Sep 10 2022, 08:28 PM
Rand   Jump (gently) up and down on the right side and w...   Sep 20 2022, 08:13 PM
rjames   Sawzall, dremel, plasma cutter... sorry, being ...   Sep 10 2022, 10:29 PM
emerygt350   Just sayin guys, that barn find I took pictures of...   Sep 11 2022, 04:37 AM
stoneman30hotmail   Just sayin guys, that barn find I took pictures o...   Sep 11 2022, 08:24 AM
Cairo94507   :wttc: Don't rush. Take the time to read a lo...   Sep 11 2022, 06:42 AM
brant   10 years ago that was a parts car Nothing a few t...   Sep 11 2022, 06:59 AM
930cabman   10 years ago that was a parts car Nothing a few ...   Sep 11 2022, 08:03 AM
mepstein   Both cars need a lot of work. A lot of the Porsche...   Sep 11 2022, 09:47 AM
Superhawk996   Both cars need a lot of work. A lot of the Porsch...   Sep 11 2022, 10:08 AM
mepstein   Both cars need a lot of work. A lot of the Porsc...   Sep 11 2022, 10:21 AM
stoneman30hotmail   There’s just something to be said for the eter...   Sep 12 2022, 09:05 AM
Superhawk996   There’s just something to be said for the ete...   Sep 12 2022, 09:50 AM
nathanxnathan   I believe there's some rust on the inside of ...   Sep 12 2022, 12:30 PM
porschetub   [quote name='stoneman30hotmail' post='3028981' da...   Sep 12 2022, 10:57 PM
bbrock   There’s just something to be said for the ete...   Sep 12 2022, 01:40 PM
stoneman30hotmail   Get the chassis supported and secure, then spend...   Sep 12 2022, 03:17 PM
Wadesbrain   Ok so I think this sounds basic but it needs to be...   Sep 11 2022, 05:17 PM
930cabman   Ok so I think this sounds basic but it needs to b...   Sep 11 2022, 05:30 PM
SirAndy   Also check the "914 Info" at the top o...   Sep 11 2022, 06:00 PM
bbrock   Ok so I think this sounds basic but it needs to b...   Sep 11 2022, 09:46 PM
930cabman   [quote name='Wadesbrain' post='3028821' date='Sep...   Sep 12 2022, 12:27 PM
Superhawk996   There is no “zero” datum specified that I’m ...   Sep 11 2022, 06:03 PM
Eric_Shea   :agree:   Sep 11 2022, 06:39 PM
mepstein   Because fixing cosmetic issues would be a waste of...   Sep 12 2022, 09:19 AM
TRS63   I see it like the two previous poster..this car ha...   Sep 12 2022, 11:43 AM
friethmiller   Stoneman, You are most welcome to take a look at ...   Sep 12 2022, 02:05 PM
Wadesbrain   Stoneman, You are most welcome to take a look at...   Sep 14 2022, 08:20 PM
stoneman30hotmail   Stoneman, You are most welcome to take a look at...   Sep 21 2022, 05:41 PM
friethmiller   That does look like a nice way to handle it with...   Oct 27 2022, 07:50 AM
brant   many of us... have lived through the same senario....   Sep 12 2022, 02:52 PM
stoneman30hotmail   Wow guys, thanks for all the attention and referen...   Sep 18 2022, 05:47 PM
nathanxnathan   I've seen pictures where there is an inside p...   Sep 19 2022, 02:10 PM
bbrock   It's not going to be cheap or easy, you'r...   Sep 19 2022, 05:27 PM
bbrock   I believe the octagonal rotisserie is both a suppo...   Sep 18 2022, 06:25 PM
Cairo94507   Do it right or don't do it at all. The worst ...   Sep 19 2022, 04:18 PM
Superhawk996   Any pictures of what’s going on with the other s...   Sep 19 2022, 05:28 PM
stoneman30hotmail   Any pictures of what’s going on with the other ...   Sep 20 2022, 04:05 PM
rjames   Not a chance. :)   Sep 20 2022, 04:30 PM
stoneman30hotmail   Not a chance. :) Anybody tracked costs? I w...   Sep 20 2022, 06:20 PM
worn   Been there myself. My latest has taken two years ...   Sep 20 2022, 04:39 PM
mepstein   I don’t think you can restore a rusty car for ...   Sep 20 2022, 06:45 PM
Superhawk996   If you’re doing this to make money - you’re do...   Sep 20 2022, 07:47 PM
bbrock   We need to stop saying you can't restore these...   Sep 20 2022, 10:46 PM
Superhawk996   We don't consider our time costs for going f...   Sep 20 2022, 11:01 PM
930cabman   We don't consider our time costs for going ...   Sep 21 2022, 05:00 AM
brant   Bringing dollar signs into this discussion… ? ...   Sep 21 2022, 07:24 AM
mepstein   The "labor of love" will be different fo...   Sep 21 2022, 07:41 AM
Front yard mechanic   Set up a bunch of cameras run it off a tall cliff ...   Sep 21 2022, 07:43 AM
Superhawk996   Set up a bunch of cameras run it off a tall cliff...   Sep 21 2022, 08:29 AM
rhodyguy   Was this the first 914 you looked at? Does it even...   Sep 21 2022, 09:28 AM
bbrock   Like Mark said, only the owner can decide what to ...   Sep 21 2022, 09:36 AM
friethmiller   :agree: Yes!! Well said. My '74 LE ...   Sep 21 2022, 09:51 AM
stoneman30hotmail   Poking at this slowly. I cut away more so I could...   Oct 26 2022, 07:09 PM
bbrock   Is there something to do short of using a whole n...   Oct 27 2022, 04:34 PM
mepstein   Suspension console jig http://www.914world.com/bb...   Oct 27 2022, 10:28 AM
930cabman   Suspension console jig http://www.914world.com/b...   Oct 27 2022, 04:47 PM
DaveB   This is what I picked-up: I found too many sus...   Oct 27 2022, 12:32 PM
stoneman30hotmail   Exposed a bit more. So I'm wondering how...   Oct 29 2022, 11:35 AM
bbrock   So I'm wondering how much of this I can reuse...   Oct 29 2022, 04:03 PM
dlee6204   Exposed a bit more. Whatever I can haul off f...   Oct 29 2022, 12:58 PM
dlee6204   You are on a budget so you'll have to decide ...   Oct 29 2022, 04:06 PM
stoneman30hotmail   Thanks for the replies. Do you mean this stuff...   Nov 2 2022, 07:09 PM
bbrock   Do you mean this stuff for rust remove? https://...   Nov 2 2022, 10:44 PM
Superhawk996   This piece of sheet metal from Auto Atlanta is wha...   Nov 2 2022, 07:28 PM
stoneman30hotmail   This piece of sheet metal from Auto Atlanta is wh...   Nov 4 2022, 05:27 PM
Superhawk996   This piece of sheet metal from Auto Atlanta is w...   Nov 5 2022, 07:46 AM
stoneman30hotmail   I'm glad to see my thread made it through the ...   Jan 1 2023, 02:45 PM
Dlee6205   Looks like you lost 1/16"? Maybe a smidge mo...   Jan 1 2023, 06:14 PM
Geezer914   I would stop working on this car and look for a ca...   Jan 1 2023, 08:01 PM
stoneman30hotmail   I would stop working on this car and look for a c...   Jan 2 2023, 11:21 AM
rjames   If I was going to spend 30K on a car I would be ...   Jan 2 2023, 12:16 PM
76-914   Glad to see you navigated past the nay sayers. Des...   Jan 1 2023, 09:17 PM
Superhawk996   Your door braces are way to weak to be of any use ...   Jan 2 2023, 01:05 AM
stoneman30hotmail   Your door braces are way to weak to be of any use...   Jan 2 2023, 11:22 AM
bbrock   Your door braces are way to weak to be of any us...   Jan 2 2023, 12:23 PM
stoneman30hotmail   [quote name='stoneman30hotmail' post='3048791' da...   Jan 3 2023, 04:42 PM
Superhawk996   I think the issue wasn't so much the turnbu...   Jan 3 2023, 08:03 PM
Superhawk996   I would think welding in the wheel house shouldn...   Jan 3 2023, 08:18 PM
stoneman30hotmail   [quote name='stoneman30hotmail' post='3049028' da...   Jan 4 2023, 05:20 PM
bbrock   I think the issue wasn't so much the turnbuc...   Jan 4 2023, 08:55 AM
Superhawk996   I haven’t seen this thread in a while. Great jo...   Jan 2 2023, 01:23 AM
rhodyguy   Do not trust those ratchet style jack stands. DO N...   Jan 2 2023, 08:27 AM
Front yard mechanic   I think you got this :driving-girl:   Jan 3 2023, 05:51 PM
Superhawk996   I’ll apologise because my diagram is over simpli...   Jan 4 2023, 11:13 PM
jaredmcginness   Keep fighting the good fight! I think you are ...   Jan 6 2023, 06:43 AM
stoneman30hotmail   Keep fighting the good fight! I think you are...   Jan 10 2023, 07:23 PM
stoneman30hotmail   Time for some updates. I por-15 'd the insid...   Mar 30 2023, 06:18 PM
rjames   Time for some updates. I por-15 'd the insi...   Mar 31 2023, 10:36 AM
stoneman30hotmail   Time for some updates. I por-15 'd the ins...   Apr 3 2023, 03:47 PM
stoneman30hotmail   Someone said "don't trust the jack stands...   May 3 2023, 04:27 AM
mepstein   I would have made the base wider and triangulated ...   May 3 2023, 05:29 AM
Superhawk996   :agree: You’ve got a recipe for disaster brewi...   May 3 2023, 07:22 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:11 AM
