| stoneman30hotmail |
Sep 10 2022, 05:07 PM
Member ![]() ![]() Group: Members Posts: 80 Joined: 10-September 22 From: Greensboro, NC Member No.: 26,834 Region Association: South East States |
Hello all, I'm a bit new to this. I had one of these in my 20's and and did a little stick welding fixing the hell hole.
I'm not sure how to approach this. Do I need to strip all this and go on rotisserie? Or is it feasible to cut and patch this from the top The driver side floor is bondo (or something). I'm not sure what is holding the seat mounts. The passenger side seat mount right is about broken loose. There's also holes past the transverse strut into the battery area. The longs seem ok from what I can see. Can I get the sill covers off without taking the fenders off? I was worried I drill out all the rivets to figure one hidden under the fender. Any good tool recommendations for rust removal? I was thinking maybe I can get away with with https://www.restoration-design.com/store/product/PP345BR and a https://www.restoration-design.com/store/PR...duct_Code=PP325 and the seat brakets and patch the holes. ![]() |
| Superhawk996 |
Sep 20 2022, 07:47 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
If you’re doing this to make money - you’re doing it for all the wrong reasons.
You will never recoup your labor. Material costs: Sheet metal - you will be in for a couple thousand easily Paint - $700- 1000/gallon for paint. New rubber - $800 for the major seals. Add another $300 for the odds and ends. Rebuilt brakes - $1k So let’s call that $5k and we haven’t even discussed the engine, trans, or axles. Oh - suspension - call that $600 Tires - $500 There’s $6k I haven’t even mentioned details and miscellaneous stuff that literally nickel and dimes you over time. Saw blades, sandpaper, Wire wheels, etc. You do own an air compressor, air tools, spray guns, metal cutting tools, hammers, dollys, MIG welder, etc? Get the drift? Not trying to talk you out of the project but it won’t be cheap, easy, and you most likely will not earn a cent on your labor. You do it for love of a challenge and pride in DIY but not to make money. |
stoneman30hotmail Plan of Action? Sep 10 2022, 05:07 PM
Superhawk996 Read these before you do anything. You have more ... Sep 10 2022, 05:21 PM
SirAndy You have more project on your hands than you think... Sep 10 2022, 05:57 PM
bbrock
You have more project on your hands than you thin... Sep 10 2022, 10:30 PM
Mikey914 If you choose to do this sure you have a brace in ... Sep 10 2022, 06:10 PM
930cabman Welcome aboard and it looks as though you are jump... Sep 10 2022, 06:32 PM
mepstein :wttc:
The rust you see is always the tip of the ... Sep 10 2022, 07:53 PM
bkrantz Jump (gently) up and down on the right side and wa... Sep 10 2022, 08:28 PM
Rand
Jump (gently) up and down on the right side and w... Sep 20 2022, 08:13 PM
rjames
Sawzall, dremel, plasma cutter...
sorry, being ... Sep 10 2022, 10:29 PM
emerygt350 Just sayin guys, that barn find I took pictures of... Sep 11 2022, 04:37 AM
stoneman30hotmail
Just sayin guys, that barn find I took pictures o... Sep 11 2022, 08:24 AM
Cairo94507 :wttc: Don't rush. Take the time to read a lo... Sep 11 2022, 06:42 AM
brant 10 years ago that was a parts car
Nothing a few t... Sep 11 2022, 06:59 AM
930cabman
Nothing a few ... Sep 11 2022, 08:03 AM
mepstein Both cars need a lot of work. A lot of the Porsche... Sep 11 2022, 09:47 AM
Superhawk996
Both cars need a lot of work. A lot of the Porsch... Sep 11 2022, 10:08 AM
Both cars need a lot of work. A lot of the Porsc... Sep 11 2022, 10:21 AM
stoneman30hotmail
There’s just something to be said for the eter... Sep 12 2022, 09:05 AM
Superhawk996
There’s just something to be said for the ete... Sep 12 2022, 09:50 AM
nathanxnathan
I believe there's some rust on the inside of ... Sep 12 2022, 12:30 PM
porschetub
[quote name='stoneman30hotmail' post='3028981' da... Sep 12 2022, 10:57 PM
bbrock
There’s just something to be said for the ete... Sep 12 2022, 01:40 PM
stoneman30hotmail
Get the chassis supported and secure, then spend... Sep 12 2022, 03:17 PM
Wadesbrain Ok so I think this sounds basic but it needs to be... Sep 11 2022, 05:17 PM
930cabman
Ok so I think this sounds basic but it needs to b... Sep 11 2022, 05:30 PM
Also check the "914 Info" at the top o... Sep 11 2022, 06:00 PM
bbrock
Ok so I think this sounds basic but it needs to b... Sep 11 2022, 09:46 PM
930cabman
[quote name='Wadesbrain' post='3028821' date='Sep... Sep 12 2022, 12:27 PM
Superhawk996 There is no “zero” datum specified that I’m ... Sep 11 2022, 06:03 PM
Eric_Shea :agree: Sep 11 2022, 06:39 PM
mepstein Because fixing cosmetic issues would be a waste of... Sep 12 2022, 09:19 AM
TRS63 I see it like the two previous poster..this car ha... Sep 12 2022, 11:43 AM
friethmiller Stoneman,
You are most welcome to take a look at ... Sep 12 2022, 02:05 PM
Wadesbrain
Stoneman,
You are most welcome to take a look at... Sep 14 2022, 08:20 PM
stoneman30hotmail
Stoneman,
You are most welcome to take a look at... Sep 21 2022, 05:41 PM
friethmiller
That does look like a nice way to handle it with... Oct 27 2022, 07:50 AM
brant many of us... have lived through the same senario.... Sep 12 2022, 02:52 PM
stoneman30hotmail Wow guys, thanks for all the attention and referen... Sep 18 2022, 05:47 PM
nathanxnathan
I've seen pictures where there is an inside p... Sep 19 2022, 02:10 PM
bbrock
It's not going to be cheap or easy, you'r... Sep 19 2022, 05:27 PM
bbrock I believe the octagonal rotisserie is both a suppo... Sep 18 2022, 06:25 PM
Cairo94507 Do it right or don't do it at all. The worst ... Sep 19 2022, 04:18 PM
Superhawk996 Any pictures of what’s going on with the other s... Sep 19 2022, 05:28 PM
stoneman30hotmail
Any pictures of what’s going on with the other ... Sep 20 2022, 04:05 PM
rjames
Not a chance. :) Sep 20 2022, 04:30 PM
stoneman30hotmail
Not a chance. :)
Anybody tracked costs? I w... Sep 20 2022, 06:20 PM
worn Been there myself. My latest has taken two years ... Sep 20 2022, 04:39 PM
mepstein I don’t think you can restore a rusty car for ... Sep 20 2022, 06:45 PM
bbrock We need to stop saying you can't restore these... Sep 20 2022, 10:46 PM
Superhawk996
We don't consider our time costs for going f... Sep 20 2022, 11:01 PM
930cabman
We don't consider our time costs for going ... Sep 21 2022, 05:00 AM
brant Bringing dollar signs into this discussion… ?
... Sep 21 2022, 07:24 AM
mepstein The "labor of love" will be different fo... Sep 21 2022, 07:41 AM
Front yard mechanic Set up a bunch of cameras run it off a tall cliff ... Sep 21 2022, 07:43 AM
Superhawk996
Set up a bunch of cameras run it off a tall cliff... Sep 21 2022, 08:29 AM
rhodyguy Was this the first 914 you looked at? Does it even... Sep 21 2022, 09:28 AM
bbrock Like Mark said, only the owner can decide what to ... Sep 21 2022, 09:36 AM
friethmiller :agree:
Yes!! Well said. My '74 LE ... Sep 21 2022, 09:51 AM
stoneman30hotmail Poking at this slowly. I cut away more so I could... Oct 26 2022, 07:09 PM
bbrock
Is there something to do short of using a whole n... Oct 27 2022, 04:34 PM
mepstein Suspension console jig
http://www.914world.com/bb... Oct 27 2022, 10:28 AM
930cabman
http://www.914world.com/b... Oct 27 2022, 04:47 PM
DaveB This is what I picked-up:
I found too many sus... Oct 27 2022, 12:32 PM
stoneman30hotmail Exposed a bit more.
So I'm wondering how... Oct 29 2022, 11:35 AM
bbrock
So I'm wondering how much of this I can reuse... Oct 29 2022, 04:03 PM
dlee6204
Exposed a bit more.
Whatever I can haul off f... Oct 29 2022, 12:58 PM
dlee6204
You are on a budget so you'll have to decide ... Oct 29 2022, 04:06 PM
stoneman30hotmail Thanks for the replies.
Do you mean this stuff... Nov 2 2022, 07:09 PM
bbrock
Do you mean this stuff for rust remove? https://... Nov 2 2022, 10:44 PM
Superhawk996 This piece of sheet metal from Auto Atlanta is wha... Nov 2 2022, 07:28 PM
stoneman30hotmail
This piece of sheet metal from Auto Atlanta is wh... Nov 4 2022, 05:27 PM
Superhawk996
This piece of sheet metal from Auto Atlanta is w... Nov 5 2022, 07:46 AM
stoneman30hotmail I'm glad to see my thread made it through the ... Jan 1 2023, 02:45 PM
Dlee6205 Looks like you lost 1/16"? Maybe a smidge mo... Jan 1 2023, 06:14 PM
Geezer914 I would stop working on this car and look for a ca... Jan 1 2023, 08:01 PM
stoneman30hotmail
I would stop working on this car and look for a c... Jan 2 2023, 11:21 AM
rjames
If I was going to spend 30K on a car I would be ... Jan 2 2023, 12:16 PM
76-914 Glad to see you navigated past the nay sayers. Des... Jan 1 2023, 09:17 PM
Superhawk996 Your door braces are way to weak to be of any use ... Jan 2 2023, 01:05 AM
stoneman30hotmail
Your door braces are way to weak to be of any use... Jan 2 2023, 11:22 AM
bbrock
Your door braces are way to weak to be of any us... Jan 2 2023, 12:23 PM
stoneman30hotmail
[quote name='stoneman30hotmail' post='3048791' da... Jan 3 2023, 04:42 PM
Superhawk996
I think the issue wasn't so much the turnbu... Jan 3 2023, 08:03 PM
Superhawk996
I would think welding in the wheel house shouldn... Jan 3 2023, 08:18 PM
stoneman30hotmail
[quote name='stoneman30hotmail' post='3049028' da... Jan 4 2023, 05:20 PM
bbrock
I think the issue wasn't so much the turnbuc... Jan 4 2023, 08:55 AM
Superhawk996 I haven’t seen this thread in a while. Great jo... Jan 2 2023, 01:23 AM
rhodyguy Do not trust those ratchet style jack stands. DO N... Jan 2 2023, 08:27 AM
Front yard mechanic I think you got this :driving-girl: Jan 3 2023, 05:51 PM
Superhawk996 I’ll apologise because my diagram is over simpli... Jan 4 2023, 11:13 PM
jaredmcginness Keep fighting the good fight!
I think you are ... Jan 6 2023, 06:43 AM
stoneman30hotmail
I think you are... Jan 10 2023, 07:23 PM
stoneman30hotmail Time for some updates.
I por-15 'd the insid... Mar 30 2023, 06:18 PM
rjames
I por-15 'd the insi... Mar 31 2023, 10:36 AM
stoneman30hotmail
I por-15 'd the ins... Apr 3 2023, 03:47 PM
stoneman30hotmail Someone said "don't trust the jack stands... May 3 2023, 04:27 AM
mepstein I would have made the base wider and triangulated ... May 3 2023, 05:29 AM
Superhawk996 :agree:
You’ve got a recipe for disaster brewi... May 3 2023, 07:22 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:43 AM |
