> What is this gap?, And why would it be dripping fluid?
mjsdt914
post Sep 21 2022, 09:24 AM
This gap is at the front of the transmission where it mates with the engine (as seen from below).
Does it have a name?
Am I missing a plug for this hole?
Any ideas why it would be dripping fluid?
Please advise. Thanks!
930cabman
post Sep 21 2022, 09:36 AM
can you identify if it's engine oil or transmission oil?
mjsdt914
post Sep 21 2022, 09:44 AM
QUOTE(930cabman @ Sep 21 2022, 09:36 AM) *
Both engine/transmission oil recently changed so both appear very similar. I am certain it is not coolant fluid )
mjsdt914   What is this gap?   Sep 21 2022, 09:24 AM
930cabman   can you identify if it's engine oil or transmi...   Sep 21 2022, 09:36 AM
mjsdt914   can you identify if it's engine oil or transm...   Sep 21 2022, 09:44 AM
emerygt350   I mean, the real problem here is that you have to...   Sep 21 2022, 09:39 AM
mjsdt914   I mean, the real problem here is that you have t...   Sep 21 2022, 09:42 AM
mgphoto   This gap is at the front of the transmission wher...   Sep 21 2022, 09:48 AM
930cabman   This gap is at the front of the transmission whe...   Sep 21 2022, 12:34 PM
mjsdt914   [quote name='mgphoto' post='3031393' date='Sep 21...   Sep 22 2022, 01:29 PM
rhodyguy   Either way, you have a leak that will require remo...   Sep 21 2022, 10:10 AM
davep   Your friction disc can be ruined by oil, not to me...   Sep 21 2022, 01:01 PM
mlindner   How much is it dripping, I'm not sure i would ...   Sep 21 2022, 03:15 PM
DRPHIL914   sometimes its hard to smell the trans fluid. You c...   Sep 21 2022, 04:06 PM
fixer34   sometimes its hard to smell the trans fluid. You ...   Sep 21 2022, 08:33 PM
JamesM   "the hole is there so that you can see the ...   Sep 22 2022, 10:39 AM
Dave_Darling   Sure makes valve adjustments a lot easier having ...   Sep 24 2022, 03:36 AM
mjsdt914   sometimes its hard to smell the trans fluid. You ...   Sep 22 2022, 01:44 PM
JamesM   This gap is at the front of the transmission wher...   Sep 21 2022, 05:31 PM
mjsdt914   This gap is at the front of the transmission whe...   Sep 22 2022, 01:32 PM
Dave_Darling   There is often a TDC mark on the edge of the flywh...   Sep 22 2022, 03:01 AM
Van B   100%, without a doubt, no debate, you have a leak ...   Sep 22 2022, 08:35 PM
mjsdt914   100%, without a doubt, no debate, you have a leak...   Sep 23 2022, 09:54 AM
Van B   [quote name='Van B' post='3031762' date='Sep 22 2...   Sep 23 2022, 10:26 PM
- Lo-Fi Version Time is now: 3rd November 2026 - 05:20 PM
