> What is this gap?, And why would it be dripping fluid?
mjsdt914
post Sep 21 2022, 09:24 AM
This gap is at the front of the transmission where it mates with the engine (as seen from below).
Does it have a name?
Am I missing a plug for this hole?
Any ideas why it would be dripping fluid?
Please advise. Thanks!
davep
post Sep 21 2022, 01:01 PM
914 Historian
Your friction disc can be ruined by oil, not to mention the potential for slipping. Did you use synthetic oil during the changes? That could had led to the problem.
mjsdt914   What is this gap?   Sep 21 2022, 09:24 AM
930cabman   can you identify if it's engine oil or transmi...   Sep 21 2022, 09:36 AM
mjsdt914   can you identify if it's engine oil or transm...   Sep 21 2022, 09:44 AM
emerygt350   I mean, the real problem here is that you have to...   Sep 21 2022, 09:39 AM
mjsdt914   I mean, the real problem here is that you have t...   Sep 21 2022, 09:42 AM
mgphoto   This gap is at the front of the transmission wher...   Sep 21 2022, 09:48 AM
930cabman   This gap is at the front of the transmission whe...   Sep 21 2022, 12:34 PM
mjsdt914   [quote name='mgphoto' post='3031393' date='Sep 21...   Sep 22 2022, 01:29 PM
rhodyguy   Either way, you have a leak that will require remo...   Sep 21 2022, 10:10 AM
davep   Your friction disc can be ruined by oil, not to me...   Sep 21 2022, 01:01 PM
mlindner   How much is it dripping, I'm not sure i would ...   Sep 21 2022, 03:15 PM
DRPHIL914   sometimes its hard to smell the trans fluid. You c...   Sep 21 2022, 04:06 PM
fixer34   sometimes its hard to smell the trans fluid. You ...   Sep 21 2022, 08:33 PM
JamesM   "the hole is there so that you can see the ...   Sep 22 2022, 10:39 AM
Dave_Darling   Sure makes valve adjustments a lot easier having ...   Sep 24 2022, 03:36 AM
mjsdt914   sometimes its hard to smell the trans fluid. You ...   Sep 22 2022, 01:44 PM
JamesM   This gap is at the front of the transmission wher...   Sep 21 2022, 05:31 PM
mjsdt914   This gap is at the front of the transmission whe...   Sep 22 2022, 01:32 PM
Dave_Darling   There is often a TDC mark on the edge of the flywh...   Sep 22 2022, 03:01 AM
Van B   100%, without a doubt, no debate, you have a leak ...   Sep 22 2022, 08:35 PM
mjsdt914   100%, without a doubt, no debate, you have a leak...   Sep 23 2022, 09:54 AM
Van B   [quote name='Van B' post='3031762' date='Sep 22 2...   Sep 23 2022, 10:26 PM
- Lo-Fi Version Time is now: 3rd November 2026 - 05:19 PM
