| mjsdt914 |
Sep 21 2022, 09:24 AM
Newbie ![]() Group: Members Posts: 27 Joined: 10-August 21 From: Whitefish, Montana 59937 Member No.: 25,791 Region Association: Rocky Mountains |
This gap is at the front of the transmission where it mates with the engine (as seen from below).
Does it have a name? Am I missing a plug for this hole? Any ideas why it would be dripping fluid? Please advise. Thanks! Attached image(s)
| DRPHIL914 |
Sep 21 2022, 04:06 PM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,971 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
sometimes its hard to smell the trans fluid. You can add a dye, get it from autozone or other favorite local parts place along with the UV light . I had a similar issue not long ago, was not sure as i had just put the transmission back in after putting a new rear main seal in the engine, and after a couple months noticed a small drip here so i put dye in the trans fluid(suspecting this due to just putting new RMS on motor) . if you suspect oil, put the dye in the motor oil and run it for a few hours and recheck with UV light. - as said by others, if the oil is leaking from the rear main seal it will get on the clutch and make a mess of it - when you pull it you will be able to see if it is leaking from the trans or the motor. - or both - thats possible too. What is the history of the motor? how many miles, how long have you owned it? the hole is there so that you can see the flywheel for timing, dont plug it. if the car sits for long long periods or sat for years, the seals will dry , deteriorate and leak. You can pull the transmission and leave the motor in, but i have found its easier to just pull them all as one unit. If you have not done this, there are good how-to instructions on Pelican Parts website, with pictures. Good luck Phil |
| fixer34 |
Sep 21 2022, 08:33 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,483 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
sometimes its hard to smell the trans fluid. You can add a dye, get it from autozone or other favorite local parts place along with the UV light . I had a similar issue not long ago, was not sure as i had just put the transmission back in after putting a new rear main seal in the engine, and after a couple months noticed a small drip here so i put dye in the trans fluid(suspecting this due to just putting new RMS on motor) . if you suspect oil, put the dye in the motor oil and run it for a few hours and recheck with UV light. - as said by others, if the oil is leaking from the rear main seal it will get on the clutch and make a mess of it - when you pull it you will be able to see if it is leaking from the trans or the motor. - or both - thats possible too. What is the history of the motor? how many miles, how long have you owned it? the hole is there so that you can see the flywheel for timing, dont plug it. if the car sits for long long periods or sat for years, the seals will dry , deteriorate and leak. You can pull the transmission and leave the motor in, but i have found its easier to just pull them all as one unit. If you have not done this, there are good how-to instructions on Pelican Parts website, with pictures. Good luck Phil "the hole is there so that you can see the flywheel for timing, dont plug it." I've never heard of a timing window on the bottom of the engine. Just what timing mark on the flywheel do you use? I believe it is for ventilation and a liquid drain, as you are seeing with engine/trans oil. |
| JamesM |
Sep 22 2022, 10:39 AM
Caretaker of 914s - Master of Fuel Injection ![]() ![]() ![]() ![]() Group: Members Posts: 2,348 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
"the hole is there so that you can see the flywheel for timing, dont plug it." I've never heard of a timing window on the bottom of the engine. Just what timing mark on the flywheel do you use? I believe it is for ventilation and a liquid drain, as you are seeing with engine/trans oil. Sure makes valve adjustments a lot easier having a window there (IMG:style_emoticons/default/confused24.gif) |
mjsdt914 What is this gap? Sep 21 2022, 09:24 AM
930cabman can you identify if it's engine oil or transmi... Sep 21 2022, 09:36 AM
mjsdt914
can you identify if it's engine oil or transm... Sep 21 2022, 09:44 AM
emerygt350 I mean, the real problem here is that you have to... Sep 21 2022, 09:39 AM
mjsdt914
I mean, the real problem here is that you have t... Sep 21 2022, 09:42 AM
mgphoto
This gap is at the front of the transmission wher... Sep 21 2022, 09:48 AM
930cabman
This gap is at the front of the transmission whe... Sep 21 2022, 12:34 PM
mjsdt914
[quote name='mgphoto' post='3031393' date='Sep 21... Sep 22 2022, 01:29 PM
rhodyguy Either way, you have a leak that will require remo... Sep 21 2022, 10:10 AM
davep Your friction disc can be ruined by oil, not to me... Sep 21 2022, 01:01 PM
mlindner How much is it dripping, I'm not sure i would ... Sep 21 2022, 03:15 PM
Dave_Darling
Sure makes valve adjustments a lot easier having ... Sep 24 2022, 03:36 AM
mjsdt914
sometimes its hard to smell the trans fluid. You ... Sep 22 2022, 01:44 PM
JamesM
This gap is at the front of the transmission wher... Sep 21 2022, 05:31 PM
mjsdt914
This gap is at the front of the transmission whe... Sep 22 2022, 01:32 PM
Dave_Darling There is often a TDC mark on the edge of the flywh... Sep 22 2022, 03:01 AM
Van B 100%, without a doubt, no debate, you have a leak ... Sep 22 2022, 08:35 PM
mjsdt914
100%, without a doubt, no debate, you have a leak... Sep 23 2022, 09:54 AM
Van B
[quote name='Van B' post='3031762' date='Sep 22 2... Sep 23 2022, 10:26 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd November 2026 - 05:19 PM |
