| VaccaRabite |
Sep 19 2022, 07:12 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,914 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Caveat: I'm using custom fuel injection (Microsquirt)
So this weekend my idle started hunting. I was pretty sure I had sprung a leak somewhere that was opening and closing a miniscule amount while the car vibrated at idle. My idle would go from 1000 RPM (where I have it set) to about 1900 RPM for a few seconds and then settle back down again. Whatever, drove the car for 300 miles anyway. Only time when it became an issue was at stop lights and trying to get through the free bridge traffic jam between NJ and PA - and then it was just an added annoyance. When I got home I did not find anything obviously wrong. I plugged my laptop in to see if my IAC had gone out of compliance. It was fine but I noted my "coolant" temps were all over the place. Coolant sensor for me is the stock location head temp sensor, plugged into my ECU. Are these things known for failing? Mine was giving readings with a 100+ degree swings every few seconds (I'm guessing cutting out), and my idle air valve was opening and closing trying to keep up, hence the idle hunting. Zach |
| dr914@autoatlanta.com |
Sep 23 2022, 11:11 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,243 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
hunting is always leanness
VaccaRabite Hunting idle Sep 19 2022, 07:12 AM
mgphoto Could be distributor advance mechanism malfunction... Sep 19 2022, 09:06 AM
VaccaRabite
Could be distributor advance mechanism malfunctio... Sep 19 2022, 09:51 AM
emerygt350
Could be distributor advance mechanism malfuncti... Sep 19 2022, 09:57 AM
GregAmy The 914 engine will generally hunt at idle when it... Sep 19 2022, 10:11 AM
Superhawk996
Coolant sensor for me is the stock location hea... Sep 19 2022, 10:11 AM
GregAmy Just re-read your first sentence in the original p... Sep 19 2022, 10:14 AM
VaccaRabite
Just re-read your first sentence in the original ... Sep 19 2022, 11:30 AM
GregAmy You're not gonna like this but...
There's... Sep 19 2022, 11:52 AM
sportlicherFahrer There's a FB group for aircooled EFI stuff. M... Sep 19 2022, 12:08 PM
emerygt350 If your temp sensor is bouncing 100 degrees that w... Sep 19 2022, 02:26 PM
JamesM I should already know this, but I forget, are you ... Sep 21 2022, 01:31 PM
VaccaRabite I bought one of the DubShop units.
I thought I ... Sep 22 2022, 01:37 PM
JamesM
I thought I... Sep 22 2022, 10:35 PM
VaccaRabite
I thought ... Sep 23 2022, 06:57 AM
GregAmy Looking at the engine, looks like I have to remove... Sep 23 2022, 08:01 AM
VaccaRabite
Looking at the engine, looks like I have to remov... Sep 26 2022, 06:04 AM
914_teener
I thought ... Sep 23 2022, 10:28 AM
VaccaRabite update to this thread.
The Dub Shop temp sensor f... Oct 2 2022, 09:10 PM
emerygt350 Awesome. Oct 3 2022, 05:40 AM![]() ![]() |
Lo-Fi Version | Time is now: 13th September 2026 - 10:36 PM |
