> What is this gap?, And why would it be dripping fluid?
mjsdt914
post Sep 21 2022, 09:24 AM
This gap is at the front of the transmission where it mates with the engine (as seen from below).
Does it have a name?
Am I missing a plug for this hole?
Any ideas why it would be dripping fluid?
Please advise. Thanks!
DRPHIL914
post Sep 21 2022, 04:06 PM
Dr. Phil
sometimes its hard to smell the trans fluid. You can add a dye, get it from autozone or other favorite local parts place along with the UV light . I had a similar issue not long ago, was not sure as i had just put the transmission back in after putting a new rear main seal in the engine, and after a couple months noticed a small drip here so i put dye in the trans fluid(suspecting this due to just putting new RMS on motor) . if you suspect oil, put the dye in the motor oil and run it for a few hours and recheck with UV light.
- as said by others, if the oil is leaking from the rear main seal it will get on the clutch and make a mess of it - when you pull it you will be able to see if it is leaking from the trans or the motor. - or both - thats possible too.
What is the history of the motor? how many miles, how long have you owned it?
the hole is there so that you can see the flywheel for timing, dont plug it.
if the car sits for long long periods or sat for years, the seals will dry , deteriorate and leak.
You can pull the transmission and leave the motor in, but i have found its easier to just pull them all as one unit.
If you have not done this, there are good how-to instructions on Pelican Parts website, with pictures.
Good luck
Phil
fixer34
post Sep 21 2022, 08:33 PM
QUOTE(DRPHIL914 @ Sep 21 2022, 05:06 PM) *
Good luck
Phil
"the hole is there so that you can see the flywheel for timing, dont plug it."
I've never heard of a timing window on the bottom of the engine. Just what timing mark on the flywheel do you use?
I believe it is for ventilation and a liquid drain, as you are seeing with engine/trans oil.
JamesM
post Sep 22 2022, 10:39 AM
QUOTE(fixer34 @ Sep 21 2022, 06:33 PM) *
Sure makes valve adjustments a lot easier having a window there (IMG:style_emoticons/default/confused24.gif)
Dave_Darling
post Sep 24 2022, 03:36 AM
914 Idiot
QUOTE(JamesM @ Sep 22 2022, 09:39 AM) *
I do my valve adjusts under the car using that window. I put a mark 180 out from the TDC mark and use each one.
--DD
mjsdt914   What is this gap?   Sep 21 2022, 09:24 AM
930cabman   can you identify if it's engine oil or transmi...   Sep 21 2022, 09:36 AM
mjsdt914   can you identify if it's engine oil or transm...   Sep 21 2022, 09:44 AM
emerygt350   I mean, the real problem here is that you have to...   Sep 21 2022, 09:39 AM
mjsdt914   I mean, the real problem here is that you have t...   Sep 21 2022, 09:42 AM
mgphoto   This gap is at the front of the transmission wher...   Sep 21 2022, 09:48 AM
930cabman   This gap is at the front of the transmission whe...   Sep 21 2022, 12:34 PM
mjsdt914   [quote name='mgphoto' post='3031393' date='Sep 21...   Sep 22 2022, 01:29 PM
rhodyguy   Either way, you have a leak that will require remo...   Sep 21 2022, 10:10 AM
davep   Your friction disc can be ruined by oil, not to me...   Sep 21 2022, 01:01 PM
mlindner   How much is it dripping, I'm not sure i would ...   Sep 21 2022, 03:15 PM
DRPHIL914   sometimes its hard to smell the trans fluid. You c...   Sep 21 2022, 04:06 PM
fixer34   sometimes its hard to smell the trans fluid. You ...   Sep 21 2022, 08:33 PM
JamesM   "the hole is there so that you can see the ...   Sep 22 2022, 10:39 AM
Dave_Darling   Sure makes valve adjustments a lot easier having ...   Sep 24 2022, 03:36 AM
mjsdt914   sometimes its hard to smell the trans fluid. You ...   Sep 22 2022, 01:44 PM
JamesM   This gap is at the front of the transmission wher...   Sep 21 2022, 05:31 PM
mjsdt914   This gap is at the front of the transmission whe...   Sep 22 2022, 01:32 PM
Dave_Darling   There is often a TDC mark on the edge of the flywh...   Sep 22 2022, 03:01 AM
Van B   100%, without a doubt, no debate, you have a leak ...   Sep 22 2022, 08:35 PM
mjsdt914   100%, without a doubt, no debate, you have a leak...   Sep 23 2022, 09:54 AM
Van B   [quote name='Van B' post='3031762' date='Sep 22 2...   Sep 23 2022, 10:26 PM
- Lo-Fi Version Time is now: 3rd November 2026 - 05:16 PM
