> Belt flying off 4 times now
scottsilvertt
post Sep 20 2022, 08:04 AM
scottsilvertt
I took my engine out of my car.
Repainted all sheet metal, repaired this and that.
Put the engine back in.
Put on a new German belt, it flew off in 10 minutes. And then again.
Put the old belt on, that has flown off twice.
Using a straight edge, I can measure a 1/2 inch misalignment in the pulleys.
I can’t even imagine how they became misaligned.
I would think it could only go back together one way.
The alternator pulley is further out towards front of car.
With the engine pulley closer to rear of car.
The engine pulley seems nice and flush around its surrounding cover stuff.
I can only imagine that the alt pulley is turned around.
So, I can try flipping that.
But is there a spacer behind the engine pulley? I don’t think I ever removed the engine fan/pulley.
Dave_Darling
post Sep 24 2022, 04:03 AM
914 Idiot
Replacing the alternator is possible without dropping the motor. You may have to remove the left-front piece of engine tin--I did on my car, but I don't remember if it was actually necessary. There were also a bunch of times that I worked from the top side then the bottom side and went back and forth like that.
Of course, once I got it all back together I forgot to hook up the charging wire to the starter... D'OH! A quick fix, but took a little while to notice the error.
--DD
bbrock
post Sep 24 2022, 08:00 AM
QUOTE(Dave_Darling @ Sep 24 2022, 04:03 AM) *
--DD
I just did this a month ago. Yes, left front engine tin has to come off. I also had to remove the left warm air guide from the heat exchanger to have room to pull the alternator. I think you might have room to flip the bracket without taking the alternator out of its bracket though.
930cabman
post Sep 24 2022, 08:05 AM
QUOTE(bbrock @ Sep 24 2022, 08:00 AM) *
--DD
I just replaced the alternator last week and did not remove the tin, but probably much easier. There may have been a few choice Italian words used in the process. I did not have the heat pipes installed prior
- Lo-Fi Version Time is now: 29th October 2026 - 12:17 AM
