| trick-e |
Sep 25 2022, 07:52 PM
Still Learning ![]() ![]() Group: Members Posts: 122 Joined: 7-July 12 From: Traverse City, MI USA Member No.: 14,644 Region Association: Upper MidWest
Hi team,
I’m dealing with an oil leak and suspect it may be a gummed up oil pressure relief valve/spring. Best I can tell, the pressure is blowing out the oil filter seal. I’ve replaced the oil cooler seals (twice in fact, just to make sure),the oil filter and there’s no leak around the oil pressure sensor line. No pushrod tube leaks either. Are there pressure valve/kit replacements that are better than others, for a stock ‘73 2.0? Spirited street use. I see an Empi kit and one from Tangerine Racing. Looking for opinions on products. |
| GregAmy |
Sep 26 2022, 07:20 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,717 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
trick-e oil pressure relief valve kit Sep 25 2022, 07:52 PM
SA-914 I'm still chasing weird pressures and leaks...... Sep 26 2022, 07:17 AM
trick-e
I'm still chasing weird pressures and leaks..... Sep 26 2022, 08:07 AM
brant They “gum up” by sticking in the bore of the b... Sep 26 2022, 07:59 AM
Cairo94507 Were you checking that with a mechanical gauge? 65... Sep 26 2022, 11:06 AM
trick-e
Were you checking that with a mechanical gauge? 6... Sep 26 2022, 09:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 8th November 2026 - 12:17 AM |
