Hella euro tail light lense repair, anyone heated and rebent them to suit housing ? |
porschetub |
Sep 24 2022, 03:37 PM
Advanced Member Group: Members Posts: 4,703 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Back working on my car and found trunk has some water in it,located the leak to the LH side light,sealing rubber is good but lense is bent so seal not contacting housing.
I remember some folks heating their poor fitting aftermarket ones to correct this issue ,would be interested to hear from those that have done this. Kinda cautious about this as its a genuine lense and in good condition besides. TIA,cheers |
scallyk9 |
Sep 25 2022, 12:58 PM
Member Group: Members Posts: 323 Joined: 16-October 16 From: Port Orchard, WA, USA Member No.: 20,499 Region Association: Pacific Northwest |
First thing to check is whether your leak is the lense or actually is the housing. I've got 3 sets of housings here most of which are trash because of warpage. The since the mounting points are different for the lamp housing and the lense, pressure is not the same for each.
My solution turned out to be replica housings so I could use my new NOS Hella lenses. |
porschetub |
Sep 25 2022, 08:57 PM
First thing to check is whether your leak is the lense or actually is the housing. I've got 3 sets of housings here most of which are trash because of warpage. The since the mounting points are different for the lamp housing and the lense, pressure is not the same for each. My solution turned out to be replica housings so I could use my new NOS Hella lenses. Thanks will check that but suspect lense,cheers. |
porschetub |
Sep 28 2022, 07:25 PM
First thing to check is whether your leak is the lense or actually is the housing. I've got 3 sets of housings here most of which are trash because of warpage. The since the mounting points are different for the lamp housing and the lense, pressure is not the same for each. My solution turned out to be replica housings so I could use my new NOS Hella lenses. Thanks will check that but suspect lense,cheers. Didn't have the balls to re-bend the lense so went in trying to find the cause of the leak,turns out the leak was @ the opposite end of the lense due to no seal contact. Popped out the seal and reversed it in the lense and it still fitted nice and evidence it was sealing all the way around @ all points ...a win ,no more leaks. Couple of days later I also noted my new trunk lid rubbers had about 80% contacting the lid so reset the rear stops and adjusted the latch...another win. Well pleased as an easy solution . |
Lo-Fi Version | Time is now: 1st June 2024 - 04:18 AM |
