| pcdarks |
Apr 7 2021, 06:58 PM
Member ![]() ![]() Group: Members Posts: 80 Joined: 22-June 13 Member No.: 16,037 Region Association: None |
I was reading somewhere here about how difficult it is to get the tubes from the reservoir into the grommets on the master cylinder. I greased them up with caliper assembly lube and they slipped in as easy as a 50 year ol....well lets just say they went right in.
| bbrock |
Apr 7 2021, 07:53 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
I also used brake assembly lube and pulled them on using a brake flare wrench (a trick I picked up from a member on another thread). Also, the grommets that came with my 914rubber MC leaked. It could have been operator error but the ATE grommets I bought from Porsche to replace them seemed to be a heftier rubber and have worked fine. And yes, I had the washers installed, and yes, they are needed.
| Chris914n6 |
Oct 3 2022, 01:56 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,554 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
My new 914rubber M/C leaks too. The tubes seem a little loose in the grommets, specially compared to the Uro grommets I used when the factory grommets deteriorated in my original.
It arrived pre-assembled so I assume it has washers. It only leaks drops so I haven't gotten back into it yet. FYI, I unbolted the reservoir so I could pull the hoses down enough to get a good grip on them with the M/C not bolted to the car. I also used brake assembly lube and pulled them on using a brake flare wrench (a trick I picked up from a member on another thread). Also, the grommets that came with my 914rubber MC leaked. It could have been operator error but the ATE grommets I bought from Porsche to replace them seemed to be a heftier rubber and have worked fine. And yes, I had the washers installed, and yes, they are needed. |
pcdarks Easy way to install Master cylinder reservoir tubes Apr 7 2021, 06:58 PM
mepstein Did you include the metal washers? Apr 7 2021, 07:11 PM
pcdarks
I'm confu... Apr 7 2021, 07:20 PM
infraredcalvin
I'm conf... Apr 7 2021, 07:25 PM
pcdarks
[quote name='pcdarks' post='2906394' date='Apr 7 ... Apr 7 2021, 07:45 PM
pcdarks There are no washers. The incoming lines are flare... Apr 7 2021, 07:16 PM
There are no washers. The incoming lines are flar... Apr 7 2021, 07:34 PM
JLance67
There are no washers. The incoming lines are fla... Oct 24 2022, 08:10 AM
bdstone914
[quote name='pcdarks' post='2906393' date='Apr 7... Oct 24 2022, 08:37 AM
JLance67
[quote name='JLance67' post='3037465' date='Oct 2... Oct 27 2022, 12:52 AM
Superhawk996
It's like they slowly apply until they compl... Oct 27 2022, 06:31 AM
infraredcalvin I’ve done this several times and have struggled ... Apr 7 2021, 07:23 PM
bkrantz Assuming this is for a replacement MC, I think the... Apr 7 2021, 07:43 PM
pcdarks
Assuming this is for a replacement MC, I think th... Apr 7 2021, 07:46 PM
pcdarks
I also used brake assembly lube and pulled them o... Apr 7 2021, 08:11 PM
bbrock
[quote name='bbrock' post='2906407' date='Apr 7 2... Apr 7 2021, 08:32 PM
I also used brake assembly lube and pulled them ... Apr 7 2021, 08:43 PM
Morrie
My new 914rubber M/C leaks too. The tubes seem a ... Oct 3 2022, 02:22 PM
914werke :popcorn: Apr 7 2021, 08:16 PM
bbrock Oh, and I'm a huge fan of 914Rubber and have b... Apr 7 2021, 08:53 PM
Morrie
Oh, and I'm a huge fan of 914Rubber and have ... Oct 3 2022, 12:19 PM
bbrock
Oh, and I'm a huge fan of 914Rubber and have... Oct 3 2022, 01:04 PM
Morrie
Hi Brent,
I realize this is a super old post. A... Oct 3 2022, 02:18 PM
IronHillRestorations If the grommets went in really easily, the washers... Apr 7 2021, 09:14 PM
pcdarks
If the grommets went in really easily, the washer... Apr 9 2021, 04:49 PM
wysri9 Another thread that maybe saved my life.....I need... Apr 7 2021, 10:27 PM
brant hopefully there are metal washers under your newly... Apr 8 2021, 08:31 AM
Steve I just went through this. The rubber bushings wer... Apr 8 2021, 08:49 AM
mgphoto When attaching the rubber grommets after installin... Oct 3 2022, 02:02 PM
willieg Before I bought a 19 mm master cylinder from 914Ru... Oct 3 2022, 03:02 PM
Morrie
Before I bought a 19 mm master cylinder from 914R... Oct 3 2022, 03:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th September 2026 - 04:26 PM |
