Accelerator cable replacement, Dang its stuck any insight? - Problem Solved |
913B |
Oct 7 2022, 04:04 PM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
So the original came out fine. But the new one is stuck somewhere, I looked at tunnel pics and there isn't a break in the tube, or is there?
I pulled the rear tunnel access panel and pull the shifter out of the way but I don't really see anything The worst part is I cannot even pull the new one back out, it is stuck somewhere and I don't want to yank or push too hard to F things more. I thought this was a easy project but dammmmm |
VaccaRabite |
Oct 7 2022, 07:37 PM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
what brand cable are you putting in? Are the dimensions the same as the one you took out? Are you making sure to lube the heck out of it? Is the new cable kinked or damaged somewhere?
Zach |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:06 PM |
