Accelerator cable replacement, Dang its stuck any insight? - Problem Solved |
913B |
Oct 7 2022, 04:04 PM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
So the original came out fine. But the new one is stuck somewhere, I looked at tunnel pics and there isn't a break in the tube, or is there?
I pulled the rear tunnel access panel and pull the shifter out of the way but I don't really see anything The worst part is I cannot even pull the new one back out, it is stuck somewhere and I don't want to yank or push too hard to F things more. I thought this was a easy project but dammmmm |
913B |
Oct 7 2022, 04:46 PM
so I am able to pull the new one out with some slight force, the old can go back in and out no problem, the new one seems to hang up at the 2 feet mark,
i feel like i need a solid wire or something to make way, i tried rotating the cable and jiggling it to try to overcome the jam but no go .......... |
bdstone914 |
Oct 7 2022, 08:15 PM
bdstone914 Group: Members Posts: 4,539 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
so I am able to pull the new one out with some slight force, the old can go back in and out no problem, the new one seems to hang up at the 2 feet mark, i feel like i need a solid wire or something to make way, i tried rotating the cable and jiggling it to try to overcome the jam but no go .......... @913b Buy some piano wire and use it to push thur the tube. You may have a piece of the plastic sheath in the tube. You may need to flatten the end of the wire to ream out any foreign material. |
Lo-Fi Version | Time is now: 13th June 2024 - 03:05 AM |
