Hole in Throttle Body Flap, Needed or Not |
914Sixer |
Oct 4 2022, 08:32 PM
914 Guru Group: Members Posts: 8,900 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
So I bought a big bore throttle body a while back and just got around to comparing it to the stock one. Stock body has a hole in it. What is the function of the hole? To keep the idle stable? Do I need to put one in big bore? Inquiring minds want to know.
Attached thumbnail(s) |
Geezer914 |
Oct 5 2022, 01:52 PM
Geezer914 Group: Members Posts: 1,437 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
What did the larger throttle body come off of? MM size?. Don't forget to enlarge the plenum opening to match the throttle body bore. Tail pipe expander works great.
VaccaRabite |
Oct 11 2022, 06:55 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
What did the larger throttle body come off of? MM size?. Don't forget to enlarge the plenum opening to match the throttle body bore. Tail pipe expander works great. Yep! If you don't enlarge the plenum you won't see the benefits. I used an exhaust expander and bumped it out to just SLIGHTLY oversized and then worked the taper back into the plenum with a small chasing hammer until I had a perfect fit between the parts. About a thousand little taps with the hammer, but only about 15 minutes of time. Used a super thin smear or RTV instead of the rubber gasket, as the gasket was now too small anyway. Also, are you using custom EFI or just DJet/LJet? When I went from the stock TB to the 53mm GoWesty TB I was able to feel a difference, but only after retuning the engine to take advantage of the new higher top end. Zach |
Lo-Fi Version | Time is now: 5th June 2024 - 05:27 AM |
