Clutch Advice, Reuse or Replace? |
mzapisek |
Oct 9 2022, 08:43 AM
Member Group: Members Posts: 91 Joined: 10-June 04 From: Syracuse, NY Member No.: 2,188 Region Association: North East States |
I have very low mile original 1.7 (30K). I recently installed a 4 post lift and have begun doing all the 50 year service updates (SS fuel lines, shift bushings, engine refresh etc.). I am certainly a novice mechanic at best. The information on this board most definitely helps close the knowledge gap and encourages me to self perform tasks I would otherwise be unsure of. While inspecting the flywheel, clutch and pressure plate they appear to be in very good condition (no grooves or obvious signs of wear) just some slight discoloration.
Should I reuse or replace? I did purchase a new rear main seal but I do not see any signs of a leak. From other info I have read on this board the newer seals are/maybe somewhat substandard. While I welcome the opportunity to fix everything I can while the engine is out and on the stand don’t want to perform unnecessary work or look for problems that don’t exist. Would appreciate some advice. Thanks. |
rjames |
Oct 13 2022, 02:16 PM
I'm made of metal Group: Members Posts: 3,954 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
If the flywheel and pressure plate were imbalanced, would it be something one would notice/hear driving the car?
Lo-Fi Version | Time is now: 6th June 2024 - 02:59 PM |
