Voltage Regulators, Who makes a good replacement? |
Brian Fuerbach |
Oct 12 2022, 01:53 PM
Member Group: Members Posts: 119 Joined: 1-July 19 From: Orange, Ca Member No.: 23,266 Region Association: Southern California |
I have a Bosch solid state regulator and have been noticing low and erratic charge rates lately. Swapped it for a nos Bosch mechanical reg that I had in my stash. Charge rate is 13.8-14v now, perfect but, the mechanical regulator gets pretty warm after running for awhile. I measured the case at 130F. Is this normal for a mechanical regulator?
I would like to get a solid state replacement but the Bosch regs cost almost $400. What gives? did they stop making them? What is the currently recommended replacement? |
jim_hoyland |
Oct 14 2022, 07:30 PM
Get that VIN ? Group: Members Posts: 9,317 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
See: https://www.ipdusa.com/products/6781/Adjust...t-IB301A-105443
This the one I’ve used for 15 years…. (IMG:style_emoticons/default/smile.gif) Attached image(s) |
Lockwodo |
Oct 15 2022, 11:50 AM
Member Group: Members Posts: 201 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California |
See: https://www.ipdusa.com/products/6781/Adjust...t-IB301A-105443 This the one I’ve used for 15 years…. (IMG:style_emoticons/default/smile.gif) Probably a dumb question, but you're using this on a Volvo, right? The website didn't show an option for 914. Another question, how do you adjust it? Is there some sort of adjustment screw and do you have to pull the VR out to adjust it? |
jim_hoyland |
Oct 15 2022, 02:35 PM
See: https://www.ipdusa.com/products/6781/Adjust...t-IB301A-105443 This the one I’ve used for 15 years…. (IMG:style_emoticons/default/smile.gif) Probably a dumb question, but you're using this on a Volvo, right? The website didn't show an option for 914. Another question, how do you adjust it? Is there some sort of adjustment screw and do you have to pull the VR out to adjust it? It on the 914 (IMG:style_emoticons/default/smile.gif) |
Lockwodo |
Oct 20 2022, 06:15 PM
See: https://www.ipdusa.com/products/6781/Adjust...t-IB301A-105443 This the one I’ve used for 15 years…. (IMG:style_emoticons/default/smile.gif) Probably a dumb question, but you're using this on a Volvo, right? The website didn't show an option for 914. Another question, how do you adjust it? Is there some sort of adjustment screw and do you have to pull the VR out to adjust it? It on the 914 (IMG:style_emoticons/default/smile.gif) Hi all. I wasn't getting any joy from the two Hella voltage regulators I tried (see post in string above), so I decided to buy one of the adjustable VRs mentioned by Jim Hoyland. I bought this one on Amazon (manufacturer and OEM # IB301A) for $35: https://www.amazon.com/dp/B014GN1YLK?psc=1&...product_details Out of the box, the charge rate was 14.1 volts at idle. I turned the adjustment screw counter clockwise to set the charge rate at 13.7 volts. I will have to modify the bracket on the VR because the holes don't line up with the relay board mounting holes (same issue as with the Hella VR). Liking it so far! (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 6th June 2024 - 01:32 PM |
