Which fuel pressure regulator?, for running Weber 44 IDF's |
Natedog |
Jan 17 2005, 12:25 PM
Member Group: Members Posts: 107 Joined: 20-October 03 From: Fort Collins, CO Member No.: 1,265 |
Greetings,
I read through a ton of threads in the archives in search of an answer to my question....but I'm still unsure! Situation: I'm just about ready to start it up for the first time after rebuilding and installing the 2.0 in my 73 914. The CARBS are Weber 44 IDF's. The fuel pump is a Facet mounted up front under the tank. Fuel filter between tank and pump. Fuel lines are new metal brake lines in the center tunnel, 5/16 rubber hose otherwise. I understand that these carbs need about 3-5 psi. Question: Do I need a fuel pressure regulator? If so - where do I put it? If so - where do I get one?? A lot of threads suggested getting the CB Performance rotary pump setup. I'll keep that in mind but for now I'm using the Facet. Threads also commented that the Facet should be mounted on rubber bushings to reduce noise. I haven't done that...yet. Thanks for your help! I'm only days away from starting her for the FIRST time! Cheers, Nate Pictures are fun, right?! Here's one of the engine and carbs..... Attached image(s) |
Joe Ricard |
Jan 17 2005, 12:33 PM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
This is what I run. However it only runs good sometimes. CB 3 PSI pump, currently no fuel pressure regulator. May be my idle circuit problem.
44 IDF's 38 vent 50 idle 145 main w/200 air f11 emulsion tube. 11mm float setting So I guess I am in the same boat as you what is a good fuel pressure regulator? I had one of those sandwhich ones with the dial on it. Biggest piece of garbage ever. |
Lo-Fi Version | Time is now: 1st June 2024 - 01:09 AM |
