Which fuel pressure regulator?, for running Weber 44 IDF's |
Natedog |
Jan 17 2005, 12:25 PM
Member Group: Members Posts: 107 Joined: 20-October 03 From: Fort Collins, CO Member No.: 1,265 |
Greetings,
I read through a ton of threads in the archives in search of an answer to my question....but I'm still unsure! Situation: I'm just about ready to start it up for the first time after rebuilding and installing the 2.0 in my 73 914. The CARBS are Weber 44 IDF's. The fuel pump is a Facet mounted up front under the tank. Fuel filter between tank and pump. Fuel lines are new metal brake lines in the center tunnel, 5/16 rubber hose otherwise. I understand that these carbs need about 3-5 psi. Question: Do I need a fuel pressure regulator? If so - where do I put it? If so - where do I get one?? A lot of threads suggested getting the CB Performance rotary pump setup. I'll keep that in mind but for now I'm using the Facet. Threads also commented that the Facet should be mounted on rubber bushings to reduce noise. I haven't done that...yet. Thanks for your help! I'm only days away from starting her for the FIRST time! Cheers, Nate Pictures are fun, right?! Here's one of the engine and carbs..... Attached image(s) |
Natedog |
Jan 17 2005, 01:17 PM
OK - so task list looks like this now:
1. Mount Facet on rubber bushings to cut down on noise 2. Get a good regulator and gauge. 3. Mount the regulator where the lines exit the tunnel. 4. Mount the gauge in the cockpit somewhere....on the center console....which needs a bunch of reconstruction!!! I've looked at the regulator at CB Performance and Aircooled.net. Either one would be fine, right?? Could someone please confirm: Must have regulator installed BEFORE starting for FIRST time. I could confirm that myself I guess. If I don't put in the regulator, tuning is going to be pain in the butt! Cheers, Nate |
Lo-Fi Version | Time is now: 1st June 2024 - 04:22 AM |
