| brooks944 |
Dec 1 2022, 03:31 PM
Member ![]() ![]() Group: Members Posts: 249 Joined: 5-September 10 From: Kingston, TN Member No.: 12,139 Region Association: South East States |
Hi, great to see the world back! I have a 74 with a 1.8 that was rebuilt with a Webcam, 96mm cylinders an 40 webers. The car has never been right and rich to the point of washing the cylinders. The engine has been out, back in and still not right. My trusted shop thinks it’s a timing issue as well as another local shop who is well known as a 914 pro. I am pretty confident it’s not a carb issue, lots of jet and even other carbs have been tried.
My question is the shop with the car has a 2.0l GA motor that another customer gave him on some other work that’s been in storage. Instead of continuing to struggle with the 1.8, should we use the 2l (assuming it’s a good case, etc), my cylinders and cam to build a 2056? Should match the carbs, but look forward to your input and suggestions. Thanks, Rick |
| rfinegan |
Dec 1 2022, 03:57 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,207 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region
If the case is good, one verse the other will not make a difference. The crank/rods will need to be changed from a 2.0l to get you to 2056.Any timing issues can be addressed, mechanical or electrical on the rebuild.The problem should not be inherited to the new build if build if performed correctly I hope the 96 pistons are correct for the crank/rods you plan to use?
brooks944 Engine build suggestions Dec 1 2022, 03:31 PM
930cabman
Hi, great to see the world back! I have a 74... Dec 1 2022, 03:44 PM
brooks944 Thanks for replies. I think we have all fuel issu... Dec 1 2022, 05:09 PM
rfinegan 96 mm pistons have a different piston pin location... Dec 1 2022, 08:26 PM
brooks944 The 96 pistons were for the 1.8. Looking a AA’s... Dec 2 2022, 09:33 AM
GregAmy I'm trying to figure out if you're looking... Dec 2 2022, 09:43 AM
JamesM
I'm trying to figure out if you're lookin... Dec 2 2022, 11:26 AM
rfinegan piston matches up to the crank and rods combo, the... Dec 2 2022, 10:43 AM
Jack Standz
The car has never been right and rich to the poin... Dec 2 2022, 07:43 PM
brooks944 Thanks again for all the replies. I have a “fau... Dec 4 2022, 03:41 PM
Jack Standz
Thanks again for all the replies. I have a “fa... Dec 4 2022, 05:06 PM
GregAmy
Which means the fuel pump was overpowering the fl... Dec 4 2022, 08:53 PM
Jack Standz [quote name='GregAmy' date='Dec 5 2022... Dec 5 2022, 09:52 AM
Superhawk996 Might just be me but I took GregAmy’s response a... Dec 5 2022, 12:18 PM
VaccaRabite There is a lot going on in this thread.
Your 1.8 ... Dec 6 2022, 08:06 AM![]() ![]() |
Lo-Fi Version | Time is now: 7th July 2026 - 09:55 AM |
