| NS914 |
Nov 30 2022, 02:33 PM
Member ![]() ![]() Group: Members Posts: 198 Joined: 9-June 09 From: Dartmouth, Nova Scotia Member No.: 10,455 Region Association: Canada
Hi Guys,
I have been searching a bit this afternoon trying to find some nice images re How you have routed fuel lines, particularly through the rear fire wall and up to the carbs. Could I have a few of you take some pics of both how you routed the lines and also how you fixed them in place re along the fire wall etc. Truly, thank you for the 100th time for helping me out. Regards, Grant |
| friethmiller |
Dec 1 2022, 09:58 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,192 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region
Chris,
My carbs feed from the the front as well but that's only because I decided to flip them to put the throttle wheels to the back. There's just too much in the way to get a straight shot for the slave cable. My fuel line still routes from the rear and into a tee that splits in equal length lines to each carb. I pulled the Tee out a bit here for the photo. Just noticed I used the wrong type of clamp going into the Tee. Damn! Add that to my To-Do list (IMG:style_emoticons/default/biggrin.gif) Hope all this helps, Grant. ![]() |
| NS914 |
Dec 2 2022, 05:32 AM
Chris, My carbs feed from the the front as well but that's only because I decided to flip them to put the throttle wheels to the back. There's just too much in the way to get a straight shot for the slave cable. My fuel line still routes from the rear and into a tee that splits in equal length lines to each carb. I pulled the Tee out a bit here for the photo. Just noticed I used the wrong type of clamp going into the Tee. Damn! Add that to my To-Do list (IMG:style_emoticons/default/biggrin.gif) Hope all this helps, Grant. ![]() Chris, this really does....thank you for making the time to post! |
NS914 Fuel Line Routing with Dual Carbs Nov 30 2022, 02:33 PM
simonjb RE: Fuel Line Routing with Dual Carbs Nov 30 2022, 07:31 PM
simonjb RE: Fuel Line Routing with Dual Carbs Nov 30 2022, 07:33 PM
NS914 Simon, really nice set up and you solidified my th... Dec 1 2022, 07:42 AM
ChrisFoley Interesting how you set up the carbs Simon. I... Dec 1 2022, 04:56 AM
simonjb Thanks guys - I learned it from this site as well... Dec 1 2022, 08:17 AM
friethmiller I'm using Tangerine's fuel pump/filter/lin... Dec 1 2022, 08:47 AM
NS914 Such a Clean Car and thanks for posting.
Regards,... Dec 1 2022, 09:55 AM
NS914 Just reviewing again...my god you guys build beaut... Dec 2 2022, 05:30 AM
NARP74 That filter pump combo is available several places... Dec 1 2022, 09:43 AM
ndfrigi Check Nacho’s 73 2270 set up on his fuel lines. ... Dec 1 2022, 10:05 AM
NARP74
Check Nacho’s 73 2270 set up on his fuel lines.... Dec 1 2022, 10:13 AM
simonjb
Check Nacho’s 73 2270 set up on his fuel lines.... Dec 1 2022, 01:16 PM
CCE
Hi Guys,
I have been searching a bit this aftern... Apr 20 2025, 02:20 PM
mlindner Hi Grant. I went a little different route, moved ... Apr 22 2025, 11:01 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th March 2026 - 11:59 PM |
