> Structural Question, crossmember bolts in sheer or tension?
cooler
post Dec 2 2022, 06:28 PM
"Very Interesting!"
hello 914 structural experts,
I am planning to create a new crossmember to stiffen rear suspension and support engine. The 914 rear suspension console is well known to flex under racing stress and was reinforced by factory racing teams. I intend to address the flexing issue and create engine (Audi V8) mounting locations with a new crossmember and diagonal tension members. The attached photo shows the location of crossmember (red) and diagonal tension members (blue).
The crossmember spans between the suspension consoles, on center with the trailing arm pivot axis. The diagonal tension members span also from rear suspension consoles to firewall, near center tunnel. This assembly will need to be removable to facilitate engine removal and is intended to stiffen the entire engine bay/rear suspension.
I am struggling with detailing the crossmember bolted connections at suspension consoles. I assume each connections should include two bolts each but, should the bolts be loaded in shear or in tension? What size should the bolts be?
Thanks in advance
cooler
post Dec 4 2022, 04:06 PM
"Very Interesting!"
Hello Again,
Thank you all for taking the time to respond.
I have studied cars with removable subframes/crossmembers. The intent of how the loads are transferred are not always clear, sometimes rubber isolating mounting points are used. My intent is to stiffen the chassis, to maximize stress transfer no rubber insulators will be used at chassis connections. The engine however will be mounted to crossmember via rubber mounts.
I'm also thinking the load created by the engine are minimal when compared to loads transferred from the suspension. The engine loads are proportional to engine mass. The suspension loads are proportional to total mass of car.
The members must be removable vertically to facilitate engine removal. I believe if the fasters were also aligned vertically, hole alignment and reassembly would be easier. I also believe that would load the fasteners more significantly in shear if vertical load from the engine are considered negligible. Shear loads on the bolts could be reduced or eliminated by dowel pins in the connection. I have seen old school hot rod crossmember connections made with flanged connections but, they are likely not typically removable. It would be a PITA to align those bolt holes on reassembly.
I may have answered my own question but, I have one more! What, from a seat of pants perspective, to make you feel comfortable, should the crossmember be constructed of.
Thanks again
cooler   Structural Question   Dec 2 2022, 06:28 PM
Charles Freeborn   hello 914 structural experts, I am planning to c...   Dec 3 2022, 09:39 AM
stownsen914   You're correct to reinforce this area of the c...   Dec 3 2022, 11:55 AM
Brett W   Think of or go look through a junkyard and see how...   Dec 3 2022, 06:09 PM
cooler   Hello Again, Thank you all for taking the time to ...   Dec 4 2022, 04:06 PM
infraredcalvin   I'd recommend taking a look at the GT/Ferrari ...   Dec 6 2022, 03:36 PM
cooler   Yes, thanks for that. Fortunately the Audi V8 moun...   Dec 6 2022, 05:35 PM
Brett W   Use the engine as a semi stressed member.   Dec 7 2022, 09:32 AM
cooler   Semi-stressed member. What would that look like?   Dec 8 2022, 09:56 AM
Charles Freeborn   Semi-stressed member. What would that look like? ...   Dec 8 2022, 10:09 AM
cooler   Thanks for your input, Stressing the engine as a s...   Dec 9 2022, 11:41 AM
Brett W   Where are the engine mounts in relation to the rea...   Dec 9 2022, 09:07 PM
stownsen914   Personally not a big fan of solid mounted engines....   Dec 10 2022, 09:18 AM
stownsen914   Dup   Dec 10 2022, 09:18 AM
PatMc   Not a vehicle structural expert...but I know a thi...   Dec 10 2022, 03:24 PM
cooler   My apologies, these pics should have been posted. ...   Dec 10 2022, 06:45 PM
cooler   RE: Structural Question   Dec 10 2022, 06:47 PM
Charles Freeborn   Wow. Cool project. Nothing more to add comme...   Dec 11 2022, 11:19 AM
cooler   Thank you, I know I'm in over my head but, I...   Dec 11 2022, 07:15 PM
stownsen914   @cooler I saw you PM'd me, not sure if you go...   Jan 10 2023, 05:35 PM
- Lo-Fi Version Time is now: 14th July 2025 - 01:13 PM
