| CCSmith58 |
Dec 3 2022, 12:20 AM
Newbie ![]() Group: Members Posts: 12 Joined: 17-March 22 From: Southern California Member No.: 26,404 Region Association: Southern California
Hello 914world… Just renewed my Membership !! Now looking to get my moneys worth...
I’m having a ’75 914 built into a 914-6. Maybe 10 or 20 years ago I might have tried to do (some of) it myself. Now I’m more a “pay the money, turn the key” guy. Here’s a “silly” question. Likely the first of many…. How does a 915 Transaxle work when converted to a mid engine application ?? Not looking for a “how to” just an overview for personal info. I’ve searched for articles, webpages and / or videos and don't find much. I find acknowledgements of the conversion but no detailed or even general description. I see the term “flipped ring and pinion”. Does the whole gear system run backwards ?? Does just the differential run backwards ?? How would a LSD work in a converted 915 ?? Are the available 916 Kits good ?? Etc... Any info or links to info would be appreciated !! |
| Dave_Darling |
Dec 6 2022, 03:59 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,326 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Some basics, here--
The "ring and pinion" are the parts that change the rotation axis of the transmission's output to be the same axis as the wheels spin. (It does more than that, but that's the part that matters here.) This isn't from a 915 or any Porsche transmission, but it does show a ring and pinion assembly: (IMG:http://www.914world.com/bbs2/uploads_offsite/www.crawlpedia.com-121-1670320783.1.jpg) If you move the ring gear (the big one whose axis is side-to-side) onto the other side of the pinion gear (the small one whose axis is fore-and-aft) you change which direction the ring gear spins when the pinion gear spins a given direction. Since a 911 has the transmission in front of the engine, it spins the ring gear (and therefore the wheels) so the bottom of the wheel goes toward the bellhousing when the transmission is in a forward gear. The 914 has the transmission behind the engine, so spinning the bottom of the wheels toward the bellhousing would be spinning it in reverse. So you have to move the ring gear to the other side of the pinion gear in order for the wheels to turn the correct direction when a forward gear is selected. Other issues with the 915 transmission include the mounting setup, the shift linkage, and the clutch linkage. All of those need to be different when the transmission is installed in a 914. The transmission linkage usually is rather more complicated than a standard 914 linkage, unless you can find the now-rare parts to convert the 915 box to use a 916-style linkage. --DD |
CCSmith58 915 transaxle question / info Dec 3 2022, 12:20 AM
Cairo94507 Welcome. Contact Patrick Motorsports in Phoenix, ... Dec 3 2022, 07:28 AM
Welcome. Contact Patrick Motorsports in Phoenix,... Dec 3 2022, 07:34 AM
Steve :agree:
I’m running the setup in my 914. Works... Dec 3 2022, 08:30 AM
stownsen914 If you'd like to do a 915 in a 914, you might ... Dec 3 2022, 08:37 AM
Steve PMS sells all the conversion parts and shift linka... Dec 3 2022, 08:57 AM
Cairo94507 I just re-read the entire linked thread....really ... Dec 3 2022, 09:53 AM
sixnotfour Ring and Pinion Ratios are Motor specific.. early ... Dec 3 2022, 10:58 AM
troth PMB was just advertising a conversion package on F... Dec 3 2022, 11:27 AM
brant Short answer about the 915
In the 911 that it was... Dec 3 2022, 12:45 PM
echocanyons Eric and the PMB team just finished the 916 conver... Dec 4 2022, 11:16 AM
Cairo94507 I am so very jealous. PM sent. :beer2: Dec 4 2022, 11:36 AM
rgalla9146 Did the conversion myself except for R&P set u... Dec 4 2022, 12:41 PM
stownsen914 The thing I don't love about 915 conversions f... Dec 5 2022, 10:06 PM
Steve :confused:
No different than a 911…. Dec 5 2022, 11:40 PM
mepstein Martin Bott has the 916 conversion parts for sale.... Dec 6 2022, 06:34 AM
T.Rick6 CCSmith58 Question for ya, what size engine / HP ... Dec 6 2022, 06:47 AM
Cairo94507 I would spend time researching Joe Cogbill before ... Dec 6 2022, 08:23 AM
I would spend time researching Joe Cogbill before... Dec 6 2022, 09:10 AM
Steve
I would spend time researching Joe Cogbill befor... Dec 6 2022, 09:31 AM
brant To the OP
You need to check also the gearing you w... Dec 6 2022, 10:11 AM
slivel The question of hp/torque limits on the 901 transm... Dec 6 2022, 10:39 AM
brant
I also drained and replaced the gear oil every s... Dec 6 2022, 10:51 AM
slivel One other advantage of the 901 transmission is tha... Dec 6 2022, 10:48 AM
Cairo94507 @slivel - Excellent feedback re your 901 experien... Dec 6 2022, 11:00 AM
CCSmith58 GrEaT input here !! Thanks !! :... Dec 7 2022, 08:01 PM
Steve
GrEaT input here !! Thanks !! ... Dec 8 2022, 06:55 AM
Dave_Darling
So, How do you "flip" the ring gear ??... Dec 11 2022, 04:49 PM
CCSmith58
So, How do you "flip" the ring gear ?... Dec 14 2022, 12:51 PM
dr914@autoatlanta.com expensive and not worth doing. We have done severa... Dec 8 2022, 10:36 AM
slivel Good point from Steve:
"I switched to the lat... Dec 8 2022, 11:33 AM
eric9144 I have a WEVO based 915 done by Patrick Motorsport... Dec 8 2022, 11:45 AM
mepstein I was just talking about this with 914Dave today. ... Dec 8 2022, 05:17 PM
Steve
I was just talking about this with 914Dave today.... Dec 9 2022, 07:55 AM
[quote name='mepstein' post='3043990' date='Dec 8... Dec 9 2022, 08:32 AM
stownsen914 If you've ever messed with a custom shifter se... Dec 10 2022, 11:01 AM
Eric_Shea Kelly’s is amazing. With a spherical Firewall bu... Dec 8 2022, 07:59 PM
JWest Shifter information: all 915 conversions that have... Dec 10 2022, 01:12 PM
Shifter information: all 915 conversions that hav... Dec 10 2022, 01:21 PM
rgalla9146
Shifter information: all 915 conversions that hav... Dec 10 2022, 01:43 PM
Steve
Shifter information: all 915 conversions that ha... Dec 10 2022, 03:03 PM
live free & drive Here is a good thread from 914Dave about his ... Dec 10 2022, 05:41 PM
Steve
Here is a good thread from 914Dave about his ... Dec 10 2022, 06:55 PM
Here is a good thread from 914Dave about his ... Dec 10 2022, 07:38 PM
rgalla9146
[quote name='live free & drive' post='3044459... Dec 10 2022, 08:16 PM
Steve
[quote name='live free & drive' post='3044459... Dec 11 2022, 01:08 PM
6er lots of info Dec 12 2022, 05:50 PM
914dave I cant believe its been ten years since i did the ... Dec 13 2022, 01:00 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th March 2026 - 05:06 PM |
