| NARP74 |
Dec 5 2022, 02:48 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,448 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
The car I bought this summer came with a Rennshift in it with a Tangerine Racing precision shift adjuster installed. I know people don't like them, but it was in already. So I was going through some adjustments with that and found I had a clutch problem caused by a pedal board adjustment. That led me to a clutch cable issue in the back. Got that all sorted and that is where the chasing my tail started.
I cannot tell if my current shift problems are clutch or shifter adjustment issues. I have not found any definitive clutch adjustment specs, seems like you do it by feel and pedal travel. And I try to go to the shifter adjustments and it feels like clutch issues. Back and forth Need help isolating the two and and getting things worked out. Where to start? I am only one set of hands and eyes and that makes things a little harder too. Suggestions appreciated. |
| ChrisFoley |
Dec 6 2022, 06:24 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,031 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
Did you get copies of the instructions for those upgraded components?
The precision adjuster requires a specific approach to initial setup. After that it's quite simple. The clutch free-play measurement (3/4-1") referenced above is checked by pulling back on the pedal. Which is opposite to the way brake pedal free-play is measured. I like to adjust my clutch cable length so the clutch bites at around 1/3 of the full travel. edit: dave beat me to it. (IMG:style_emoticons/default/smile.gif) |
| NARP74 |
Dec 6 2022, 11:10 AM
Did you get copies of the instructions for those upgraded components? The precision adjuster requires a specific approach to initial setup. After that it's quite simple. The clutch free-play measurement (3/4-1") referenced above is checked by pulling back on the pedal. Which is opposite to the way brake pedal free-play is measured. I like to adjust my clutch cable length so the clutch bites at around 1/3 of the full travel. edit: dave beat me to it. (IMG:style_emoticons/default/smile.gif) I do have your 2 page set of info. I guess I need to go through it again. I was working through it when the clutch cable problem came up and I have been focusing on that. |
NARP74 Clutch v Shift Linkage Dec 5 2022, 02:48 PM
rjames Yeah, the Rennshift and Tangerine adjuster are hor... Dec 5 2022, 03:04 PM
NARP74
Yeah, the Rennshift and Tangerine adjuster are ho... Dec 5 2022, 03:41 PM
brant I vaguely recall the haynes manual having clutch a... Dec 5 2022, 03:09 PM
NARP74
I vaguely recall the haynes manual having clutch ... Dec 5 2022, 03:42 PM
914Toy I had a shift link adjust problem after installing... Dec 5 2022, 04:06 PM
NARP74
I had a shift link adjust problem after installin... Dec 5 2022, 04:19 PM
NARP74 The problem with the threads mentioned is that the... Dec 5 2022, 05:04 PM
Dave_Darling Clutch free play is measured with the clutch pedal... Dec 6 2022, 04:16 AM
ChrisFoley If you don't have a friend to help, can you se... Dec 6 2022, 06:29 AM
JWest Not sure where "don't like them" com... Dec 6 2022, 10:08 AM
NARP74
Not sure where "don't like them" co... Dec 6 2022, 11:13 AM![]() ![]() |
Lo-Fi Version | Time is now: 24th June 2026 - 11:27 PM |
