| Type 47 |
Dec 6 2022, 08:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 796 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None
OK, i get carbs only need one fuel line, but hey, there are 2 sticking out of the bottom of the tank.
I Did the Tangerine SS lines to eventually go back to FI, but going with the Webers to get the thing up and running. Out of the tunnel and into engine bay, what's going on with the orphan fuel line? Block it off out of the tank or in the engine bay? Which one gets blocked off? The one with the tank screen filter or the other? And What the Hell is this little white tube? Is it for the FI or does it have some function with the carbs? I don't think so but I keep seeing this tube in my disassembly pics. |
| Robarabian |
Dec 6 2022, 08:38 PM
914 A Roo ![]() ![]() ![]() Group: Members Posts: 739 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California
The one with the filter is the supply line. Do not block it off. Even with carbs you can and should run the return line. Weber makes a fitting for the dual carb setup that is a "T" banjo. You plumb supply to one side of it and run the other side to the return line. That way the fuel is being cooled and you wont vapor lock.
I assume you know you cant use the stock fuel pump, you need 3-5 psi, not 60. IF you're not running the return line, then yes, you can cap it at the tank, not the line end, which would be real dangerous. |
| type53 |
Dec 7 2022, 01:31 AM
Newbie ![]() Group: Members Posts: 1 Joined: 26-June 09 From: austria Member No.: 10,511 Region Association: None |
The one with the filter is the supply line. Do not block it off. Even with carbs you can and should run the return line. Weber makes a fitting for the dual carb setup that is a "T" banjo. You plumb supply to one side of it and run the other side to the return line. That way the fuel is being cooled and you wont vapor lock. I assume you know you cant use the stock fuel pump, you need 3-5 psi, not 60. IF you're not running the return line, then yes, you can cap it at the tank, not the line end, which would be real dangerous. |
Type 47 Fuel Injection vs. Webers Dec 6 2022, 08:10 PM
914werke White line = Vacuum line for the charcoal vapor/fu... Dec 6 2022, 08:12 PM
Type 47
White line = Vacuum line for the charcoal vapor/f... Dec 7 2022, 04:06 PM
BK911
The one with the filter is the supply line. Do no... Dec 7 2022, 11:31 AM
Superhawk996
The PMO fuel regulator is perfect for converting... Dec 7 2022, 12:32 PM
BK911
Generally speaking, it is bad practice to use a... Dec 7 2022, 12:58 PM
Type 47
The one with the filter is the supply line. Do no... Dec 7 2022, 04:10 PM
930cabman I have ran a one line system for many years, some ... Dec 7 2022, 06:01 AM
brant
I have ran a one line system for many years, some... Dec 7 2022, 08:30 AM
930cabman
I have ran a one line system for many years, som... Dec 7 2022, 10:35 AM
Superhawk996
[quote name='brant' post='3043672' date='Dec 7 20... Dec 7 2022, 10:42 AM
Superhawk996 @bk911
I agree with your assessment. I was lar... Dec 7 2022, 02:57 PM
brant Vapor lock is real
The reason thousands of us rel... Dec 7 2022, 02:59 PM
914werke @bk911 What specific PMO Fuel Pump are you referr... Dec 7 2022, 03:20 PM
BK911 Regulator, not pump.
With this regulator and prope... Dec 7 2022, 03:29 PM
BK911
Supply on left bottom, return on left top.
Top ... Dec 7 2022, 03:34 PM
Gatornapper I'm using a Holley fuel pressure regulator and... Dec 7 2022, 04:48 PM
Superhawk996 Back in the day . . . . I could buy a whole 914 fo... Dec 7 2022, 03:42 PM
campbellcj FWIW my car has no return line either and I've... Dec 7 2022, 04:41 PM
914werke OK, one end goes on the vapor recovery tank on to... Dec 7 2022, 05:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 11:05 PM |
