> Fuel Injection vs. Webers, what's the difference in plumbing/hardware between the 2
Type 47
post Dec 6 2022, 08:10 PM
OK, i get carbs only need one fuel line, but hey, there are 2 sticking out of the bottom of the tank.
I Did the Tangerine SS lines to eventually go back to FI, but going with the Webers to get the thing up and running.
Out of the tunnel and into engine bay, what's going on with the orphan fuel line? Block it off out of the tank or in the engine bay? Which one gets blocked off? The one with the tank screen filter or the other?
And What the Hell is this little white tube? Is it for the FI or does it have some function with the carbs? I don't think so but I keep seeing this tube in my disassembly pics.
930cabman
post Dec 7 2022, 06:01 AM
I have ran a one line system for many years, some guys will utilize a return line, but why?
Also, I run the Webers on several of my cars on 2 - 3 psi. They have never been fuel starved and Webers are sensitive to over pressuring.
brant
post Dec 7 2022, 08:30 AM
QUOTE(930cabman @ Dec 7 2022, 05:01 AM) *
Cooler fuel
Less vapor lock !
More hp
That’s why
Type 47   Fuel Injection vs. Webers   Dec 6 2022, 08:10 PM
914werke   White line = Vacuum line for the charcoal vapor/fu...   Dec 6 2022, 08:12 PM
Type 47   White line = Vacuum line for the charcoal vapor/f...   Dec 7 2022, 04:06 PM
Robarabian   The one with the filter is the supply line. Do not...   Dec 6 2022, 08:38 PM
type53   The one with the filter is the supply line. Do no...   Dec 7 2022, 01:31 AM
BK911   The one with the filter is the supply line. Do no...   Dec 7 2022, 11:31 AM
Superhawk996   The PMO fuel regulator is perfect for converting...   Dec 7 2022, 12:32 PM
BK911   Generally speaking, it is bad practice to use a...   Dec 7 2022, 12:58 PM
Type 47   The one with the filter is the supply line. Do no...   Dec 7 2022, 04:10 PM
930cabman   I have ran a one line system for many years, some ...   Dec 7 2022, 06:01 AM
brant   I have ran a one line system for many years, some...   Dec 7 2022, 08:30 AM
930cabman   I have ran a one line system for many years, som...   Dec 7 2022, 10:35 AM
Superhawk996   [quote name='brant' post='3043672' date='Dec 7 20...   Dec 7 2022, 10:42 AM
Superhawk996   @bk911 I agree with your assessment. I was lar...   Dec 7 2022, 02:57 PM
brant   Vapor lock is real The reason thousands of us rel...   Dec 7 2022, 02:59 PM
914werke   @bk911 What specific PMO Fuel Pump are you referr...   Dec 7 2022, 03:20 PM
BK911   Regulator, not pump. With this regulator and prope...   Dec 7 2022, 03:29 PM
BK911   Supply on left bottom, return on left top. Top ...   Dec 7 2022, 03:34 PM
Gatornapper   I'm using a Holley fuel pressure regulator and...   Dec 7 2022, 04:48 PM
Superhawk996   Back in the day . . . . I could buy a whole 914 fo...   Dec 7 2022, 03:42 PM
campbellcj   FWIW my car has no return line either and I've...   Dec 7 2022, 04:41 PM
914werke   OK, one end goes on the vapor recovery tank on to...   Dec 7 2022, 05:05 PM
- Lo-Fi Version Time is now: 14th April 2026 - 11:04 PM
