| Type 47 |
Dec 6 2022, 08:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 796 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None
OK, i get carbs only need one fuel line, but hey, there are 2 sticking out of the bottom of the tank.
I Did the Tangerine SS lines to eventually go back to FI, but going with the Webers to get the thing up and running. Out of the tunnel and into engine bay, what's going on with the orphan fuel line? Block it off out of the tank or in the engine bay? Which one gets blocked off? The one with the tank screen filter or the other? And What the Hell is this little white tube? Is it for the FI or does it have some function with the carbs? I don't think so but I keep seeing this tube in my disassembly pics. |
| Robarabian |
Dec 6 2022, 08:38 PM
914 A Roo ![]() ![]() ![]() Group: Members Posts: 739 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California
The one with the filter is the supply line. Do not block it off. Even with carbs you can and should run the return line. Weber makes a fitting for the dual carb setup that is a "T" banjo. You plumb supply to one side of it and run the other side to the return line. That way the fuel is being cooled and you wont vapor lock.
I assume you know you cant use the stock fuel pump, you need 3-5 psi, not 60. IF you're not running the return line, then yes, you can cap it at the tank, not the line end, which would be real dangerous. |
| BK911 |
Dec 7 2022, 11:31 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
The one with the filter is the supply line. Do not block it off. Even with carbs you can and should run the return line. Weber makes a fitting for the dual carb setup that is a "T" banjo. You plumb supply to one side of it and run the other side to the return line. That way the fuel is being cooled and you wont vapor lock. I assume you know you cant use the stock fuel pump, you need 3-5 psi, not 60. IF you're not running the return line, then yes, you can cap it at the tank, not the line end, which would be real dangerous. Just for clarification... The pump does not produce 60 psi unless the system is designed that way. With a supply and return line, the pump will not make anywhere 60 unless there are restrictions somewhere in the line. The PMO fuel regulator is perfect for converting from FI to carbs. With a stock pump, adjust the return pressure drop until the pressure hits ~4 psi. |
| Superhawk996 |
Dec 7 2022, 12:32 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,779 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
The PMO fuel regulator is perfect for converting from FI to carbs. With a stock pump, adjust the return pressure drop until the pressure hits ~4 psi. Generally speaking, it is bad practice to use a high pressure fuel pump intended for fuel injection to feed carbs. Makes no sense to use a pump capable of 30 psi to feed 3 psi to carbs. Pumping fuel up to high pressure and then regulating it down just adds extra heat to the fuel. There is a reason Porsche used a different low pressure fuel pump for the /6 carb equipped cars. Then there is an added failure mode with a high pressure FI fuel pump. If the pressure regulator fails, you'll have high pressure fuel at the carbs which will completely overwhelm the float and flood the carb fuel bowls. Far better to have a low pressure (~5 psi pump) that is regulated to 3 psi. Then if the regulator fails, car will still run (but poorly). |
Type 47 Fuel Injection vs. Webers Dec 6 2022, 08:10 PM
914werke White line = Vacuum line for the charcoal vapor/fu... Dec 6 2022, 08:12 PM
Type 47
White line = Vacuum line for the charcoal vapor/f... Dec 7 2022, 04:06 PM
type53
The one with the filter is the supply line. Do no... Dec 7 2022, 01:31 AM
BK911
Generally speaking, it is bad practice to use a... Dec 7 2022, 12:58 PM
Type 47
The one with the filter is the supply line. Do no... Dec 7 2022, 04:10 PM
930cabman I have ran a one line system for many years, some ... Dec 7 2022, 06:01 AM
brant
I have ran a one line system for many years, some... Dec 7 2022, 08:30 AM
930cabman
I have ran a one line system for many years, som... Dec 7 2022, 10:35 AM
Superhawk996
[quote name='brant' post='3043672' date='Dec 7 20... Dec 7 2022, 10:42 AM
Superhawk996 @bk911
I agree with your assessment. I was lar... Dec 7 2022, 02:57 PM
brant Vapor lock is real
The reason thousands of us rel... Dec 7 2022, 02:59 PM
914werke @bk911 What specific PMO Fuel Pump are you referr... Dec 7 2022, 03:20 PM
BK911 Regulator, not pump.
With this regulator and prope... Dec 7 2022, 03:29 PM
BK911
Supply on left bottom, return on left top.
Top ... Dec 7 2022, 03:34 PM
Gatornapper I'm using a Holley fuel pressure regulator and... Dec 7 2022, 04:48 PM
Superhawk996 Back in the day . . . . I could buy a whole 914 fo... Dec 7 2022, 03:42 PM
campbellcj FWIW my car has no return line either and I've... Dec 7 2022, 04:41 PM
914werke OK, one end goes on the vapor recovery tank on to... Dec 7 2022, 05:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 11:04 PM |
