> Quick center cap removal method
JeffBowlsby
post Dec 6 2022, 07:52 PM
I don’t have the custom plumbing store tool to remove the center caps, and frankly didn’t want or have the time to pull the wheels to do it either. So I tried another way and it worked flawlessly.
I used a rigid chisel edged putty knife with clear packing tape wrapped over the chisel edge, a claw hammer also taped at the edge of the claws, and a hard rubber hammer.
Tap lightly and slowly on the putty knife to initially pry the stainless steel caps loose. They can be easily damaged if you get too heavy on them. Insert putty knife at each wheel bolt and the center cap begins to lift. Switch to the claw hammer bearing lightly onto each wheel bolt as a fulcrum and rotate around the cap prying it out just a little at a time.
Be patient. About 5 minutes per wheel. Change the tape protection with each wheel cap.
post Dec 6 2022, 09:18 PM
914-6 GT in waiting
We use this slide hammer tool. Takes seconds. If it’s not handy, a hammer takes a few more seconds but the slide hammer tool is slick.
bdstone914
post Dec 8 2022, 03:29 PM
bdstone914
QUOTE(mepstein @ Dec 6 2022, 09:18 PM) *
@MEPSTEIN
How does that attach to the steel cap?
Does it hold on the bumps on the outside?
post Dec 8 2022, 04:48 PM
914-6 GT in waiting
QUOTE(bdstone914 @ Dec 8 2022, 04:29 PM) *
@MEPSTEIN
Yes. 3 set screws. You can see them in the bottom of the tool. I just hand tighten and its good.
- Lo-Fi Version Time is now: 1st August 2025 - 08:45 AM
