| Type 47 |
Dec 8 2022, 03:53 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 796 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None
| GregAmy |
Dec 8 2022, 04:57 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,654 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
You will need to change to a return-type fuel pressure regulator, otherwise pressure would be almost zero as it flowed right back into the tank (easiest path).
The return will be on the bypass side of the pressure regulator. Edit: something like this should work, mounted before the feed lines to the carbs: https://www.holley.com/products/fuel_system...rs/parts/12-887 Kinda curious: why? Worried about vapor lock? You're still going to have that last bit of feed to the carbs that will not be full flow, and that's the most-common locations for vapor lock. |
Type 47 Weber carb return line Dec 8 2022, 03:53 PM
Type 47
You will need to change to a return-type fuel pre... Dec 8 2022, 07:52 PM
VaccaRabite
So in the below thread (3rd post down), it was s... Dec 8 2022, 08:54 PM
VaccaRabite :agree:
You need a regulator plumbed in. Metered... Dec 8 2022, 06:09 PM
brant Zach
The factory ran a return line
All factories ... Dec 9 2022, 08:38 AM
brant Plumbing options Dec 9 2022, 08:39 AM
914werke Option E
Oh & "while your in there... Dec 9 2022, 11:30 AM
JmuRiz What do the symbols stand for. Dec 9 2022, 01:06 PM
914werke What do the symbols stand for.
Tank Carbs Pump R... Dec 9 2022, 01:28 PM
brant
Tank Carbs Pump ... Dec 9 2022, 01:45 PM
GregAmy Oh the rectangle is the filter? I thought it was t... Dec 9 2022, 01:59 PM
NARP74 What does having the regulator after the carbs do ... Dec 9 2022, 02:19 PM
GregAmy
What does having the regulator after the carbs do... Dec 9 2022, 02:40 PM
Craigers17
One option as posted from OP's other thread... Dec 9 2022, 02:33 PM
Root_Werks I've used that option picture before and reall... Dec 9 2022, 04:07 PM
nditiz1 Here is how I mounted my PMO regulator. Originall... Dec 11 2022, 07:17 AM
bbrock I also like the "E" option but have been... Dec 11 2022, 01:27 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 12:46 AM |
