JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,982 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
I don’t have the custom plumbing store tool to remove the center caps, and frankly didn’t want or have the time to pull the wheels to do it either. So I tried another way and it worked flawlessly.
I used a rigid chisel edged putty knife with clear packing tape wrapped over the chisel edge, a claw hammer also taped at the edge of the claws, and a hard rubber hammer. Tap lightly and slowly on the putty knife to initially pry the stainless steel caps loose. They can be easily damaged if you get too heavy on them. Insert putty knife at each wheel bolt and the center cap begins to lift. Switch to the claw hammer bearing lightly onto each wheel bolt as a fulcrum and rotate around the cap prying it out just a little at a time. Be patient. About 5 minutes per wheel. Change the tape protection with each wheel cap. Attached thumbnail(s) ![]() ![]() ![]() ![]() |
Geezer914 |
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,027 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States ![]() ![]() |
Go to Home Depot and get a piece of PVC pipe that fits the I d of the rim so you can tap it out with a hammer. Bring a cap and find a PVC reducer that fits over the cap and rests on the rim of the cap. This will allow you to tap in the cap without damage.
Lo-Fi Version | Time is now: 1st August 2025 - 08:30 AM |
