| Type 47 |
Dec 8 2022, 03:53 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 796 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None
| bbrock |
Dec 11 2022, 01:27 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
I also like the "E" option but have been running "C" for 7K miles and it works well. Here's the regulator I'm running and it has worked well. The pressure to the carbs hasn't budged since originally setting to 3.5 psi.
https://www.ebay.com/itm/371739673458 (IMG:http://www.914world.com/bbs2/uploads_offsite/i.ebayimg.com-20845-1670786841.1.jpg) |
Type 47 Weber carb return line Dec 8 2022, 03:53 PM
GregAmy You will need to change to a return-type fuel pres... Dec 8 2022, 04:57 PM
Type 47
You will need to change to a return-type fuel pre... Dec 8 2022, 07:52 PM
VaccaRabite
So in the below thread (3rd post down), it was s... Dec 8 2022, 08:54 PM
VaccaRabite :agree:
You need a regulator plumbed in. Metered... Dec 8 2022, 06:09 PM
brant Zach
The factory ran a return line
All factories ... Dec 9 2022, 08:38 AM
brant Plumbing options Dec 9 2022, 08:39 AM
914werke Option E
Oh & "while your in there... Dec 9 2022, 11:30 AM
JmuRiz What do the symbols stand for. Dec 9 2022, 01:06 PM
914werke What do the symbols stand for.
Tank Carbs Pump R... Dec 9 2022, 01:28 PM
brant
Tank Carbs Pump ... Dec 9 2022, 01:45 PM
GregAmy Oh the rectangle is the filter? I thought it was t... Dec 9 2022, 01:59 PM
NARP74 What does having the regulator after the carbs do ... Dec 9 2022, 02:19 PM
GregAmy
What does having the regulator after the carbs do... Dec 9 2022, 02:40 PM
Craigers17
One option as posted from OP's other thread... Dec 9 2022, 02:33 PM
Root_Werks I've used that option picture before and reall... Dec 9 2022, 04:07 PM
nditiz1 Here is how I mounted my PMO regulator. Originall... Dec 11 2022, 07:17 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 12:46 AM |
