> Engine oil “leak”
sixaddict
post Dec 13 2022, 09:11 AM
Trying to help identifying a problem before disassembly for a guy.
2.2 4 cylinder pushing a lot of oil out of dual,outlet muffler. Seems to be heavier from one side.
Ideas on cause/ problem.
I know that’s not a lot to go on.
Thanks
914sgofast2
post Dec 13 2022, 02:25 PM
Time to do a step by step diagnostic program:
1: check for proper oil level;
2: check oil pressure sending unit to see if it is leaking;
3: do a leak down test to see where compression is leaking. If only one cylinder low, do a compression test to see how bad it is;
4: clean off oil from bottom of engine then run it to see if there is an obvious oil leak from a valve cover, push rod tube, front crankshaft seal, or oil filter and oil cooler areas.
sixaddict   Engine oil “leak”   Dec 13 2022, 09:11 AM
930cabman   History? new build? 100k miles? more info please   Dec 13 2022, 10:38 AM
sixaddict   Engine was quality build from what I know and func...   Dec 13 2022, 12:13 PM
rhodyguy   Smoke upon decel, accel or all of the time?   Dec 13 2022, 12:18 PM
sixaddict   No smoke ….oil ! All the time   Dec 13 2022, 12:34 PM
930cabman   No smoke ….oil ! All the time Oil is spit...   Dec 13 2022, 02:09 PM
SirAndy   No smoke ….oil ! All the time No smoke, ju...   Dec 13 2022, 04:08 PM
VaccaRabite   No smoke ….oil ! All the time No smoke, j...   Dec 13 2022, 04:18 PM
VaccaRabite   Have the valves ever been adjusted? I'm, sure ...   Dec 13 2022, 01:05 PM
emerygt350   any chance they overfilled the crap out of it? be...   Dec 13 2022, 01:55 PM
914sgofast2   Time to do a step by step diagnostic program: 1: c...   Dec 13 2022, 02:25 PM
sixaddict   My owners theory ( no real technical expertise) a ...   Dec 13 2022, 03:03 PM
wonkipop   My owners theory ( no real technical expertise) a...   Dec 13 2022, 03:22 PM
sixaddict   All the easy stuff has been eliminated…..compres...   Dec 13 2022, 03:14 PM
porschetub   All the easy stuff has been eliminated…..compre...   Dec 13 2022, 04:22 PM
wonkipop   the only time i have seen oil coming out the exhau...   Dec 13 2022, 03:38 PM
sixaddict   Thanks for all the ideas… I will post once we fi...   Dec 13 2022, 04:44 PM
930cabman   Thanks for all the ideas… I will post once we f...   Dec 13 2022, 05:15 PM
emerygt350   I am betting on richness but I can imagine some pr...   Dec 13 2022, 07:42 PM
- Lo-Fi Version Time is now: 15th April 2026 - 12:10 AM
