| Puebloswatcop |
Dec 18 2022, 08:07 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,701 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
Is a cylinder head temp sensor needed on a carburated car? It seems it is just for the "computer" on an FI car, but I need to clarify.
| Dave_Darling |
Dec 18 2022, 10:25 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Note that the stock CHT sensor is not the same type as those used by the CHT gauges. It's also in an area of the head that changes fairly slowly. It's not a good data source for telling you much of anything about the engine.
Use the ring-type thermocouple around the spark plug which is the standard way to get CHT readings. --DD |
Puebloswatcop Cylinder Head Temp Sensor? Dec 18 2022, 08:07 AM
914Sixer NOT required Dec 18 2022, 08:10 AM
Puebloswatcop
NOT required
Thanks,
Didn't think so, but ... Dec 18 2022, 08:17 AM
930cabman The cyl head sensor is not required for the engine... Dec 18 2022, 11:35 AM
930cabman
Note that the stock CHT sensor is not the same ty... Dec 19 2022, 06:01 AM
VaccaRabite
Note that the stock CHT sensor is not the same t... Dec 19 2022, 08:35 AM
stownsen914 Is it feasible to put the sparkplug ring sensor at... Dec 20 2022, 11:29 AM
GregAmy
Is it feasible to put the sparkplug ring sensor a... Dec 20 2022, 11:49 AM
BeatNavy The ring is attached to a long wire that leads to ... Dec 19 2022, 06:57 AM
barefoot TC mounted under #3 spark plug should be clamped d... Dec 21 2022, 07:32 AM
emerygt350 I just put mine in through the spark plug hole in ... Dec 21 2022, 07:50 AM
barefoot
I just put mine in through the spark plug hole in... Dec 22 2022, 09:25 AM
Lockwodo Hi all. I want to add a cylinder 3 thermocouple a... Dec 22 2022, 06:34 PM
VaccaRabite https://www.aircraftspruce.com/menus/in/falcon_cht... Dec 22 2022, 06:51 PM
GregAmy Quick side note for you data acq guys/gals.
Senso... Dec 22 2022, 07:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:05 PM |
