| Puebloswatcop |
Dec 18 2022, 08:07 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,701 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
Is a cylinder head temp sensor needed on a carburated car? It seems it is just for the "computer" on an FI car, but I need to clarify.
| Dave_Darling |
Dec 18 2022, 10:25 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Note that the stock CHT sensor is not the same type as those used by the CHT gauges. It's also in an area of the head that changes fairly slowly. It's not a good data source for telling you much of anything about the engine.
Use the ring-type thermocouple around the spark plug which is the standard way to get CHT readings. --DD |
| 930cabman |
Dec 19 2022, 06:01 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,572 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Note that the stock CHT sensor is not the same type as those used by the CHT gauges. It's also in an area of the head that changes fairly slowly. It's not a good data source for telling you much of anything about the engine. Use the ring-type thermocouple around the spark plug which is the standard way to get CHT readings. --DD (IMG:style_emoticons/default/headbang.gif) Thank you Dave, I have also read the same, under the spark plug is the most accurate location for cyl head temp. Can this be problematic when changing spark plugs? I can see the ring getting lost when threading a new plug into the head |
| VaccaRabite |
Dec 19 2022, 08:35 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Note that the stock CHT sensor is not the same type as those used by the CHT gauges. It's also in an area of the head that changes fairly slowly. It's not a good data source for telling you much of anything about the engine. Use the ring-type thermocouple around the spark plug which is the standard way to get CHT readings. --DD (IMG:style_emoticons/default/headbang.gif) Thank you Dave, I have also read the same, under the spark plug is the most accurate location for cyl head temp. Can this be problematic when changing spark plugs? I can see the ring getting lost when threading a new plug into the head Just grind a little groove into the boss for the wire to exit under the park plug. No big deal. The first time you put in the plug it will be challenging. But you figure out how to do it and it is easy the rest of the time. You just have to rememeber to remove the washer from the plug you have the temp sender on. Zach |
| stownsen914 |
Dec 20 2022, 11:29 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 996 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Is it feasible to put the sparkplug ring sensor at the stock CHT sensor location (presumably using a bolt)?
Puebloswatcop Cylinder Head Temp Sensor? Dec 18 2022, 08:07 AM
914Sixer NOT required Dec 18 2022, 08:10 AM
Puebloswatcop
NOT required
Thanks,
Didn't think so, but ... Dec 18 2022, 08:17 AM
930cabman The cyl head sensor is not required for the engine... Dec 18 2022, 11:35 AM
GregAmy
Is it feasible to put the sparkplug ring sensor a... Dec 20 2022, 11:49 AM
BeatNavy The ring is attached to a long wire that leads to ... Dec 19 2022, 06:57 AM
barefoot TC mounted under #3 spark plug should be clamped d... Dec 21 2022, 07:32 AM
emerygt350 I just put mine in through the spark plug hole in ... Dec 21 2022, 07:50 AM
barefoot
I just put mine in through the spark plug hole in... Dec 22 2022, 09:25 AM
Lockwodo Hi all. I want to add a cylinder 3 thermocouple a... Dec 22 2022, 06:34 PM
VaccaRabite https://www.aircraftspruce.com/menus/in/falcon_cht... Dec 22 2022, 06:51 PM
GregAmy Quick side note for you data acq guys/gals.
Senso... Dec 22 2022, 07:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:11 PM |
