> 914-6 2.7 build...Piston type?, Pistons for a weber carbed 2.7 build
zfisher6164
post Dec 31 2022, 06:13 PM
Engine rebuild on a 2.7 weber carbed engine and the pistons used 8 years ago are fuel injected pistons and I have gotten a few opinions of the type of piston to use by none are
definitive. Any ideas?
thanks
zac
Superhawk996
post Dec 31 2022, 08:22 PM
Pistons for the CIS fuel injection are not a great choice for carbs.
As stated previously - Mahle is the gold standard and bump the compression ratio. You should also ditch the mild CIS cams - your leaving HP on the table there too.
zfisher6164   914-6 2.7 build...Piston type?   Dec 31 2022, 06:13 PM
sixnotfour   2.7 Mahle MFI.. only 8.5-1 thou or 2.9 mahle motor...   Dec 31 2022, 07:14 PM
zfisher6164   thanks the pistons in the engine now look like thi...   Dec 31 2022, 07:36 PM
zfisher6164   another picture   Dec 31 2022, 07:37 PM
Superhawk996   Pistons for the CIS fuel injection are not a great...   Dec 31 2022, 08:22 PM
zfisher6164   thanks this is the info I need the previous engine...   Dec 31 2022, 08:49 PM
zfisher6164   not sure about the cam but will find out soon   Dec 31 2022, 08:50 PM
flyer86d   The engine that I built for my 1968 911 started ou...   Jan 1 2023, 11:55 AM
brant   You really need a copy of the Bruce Anderson book ...   Jan 1 2023, 12:03 PM
JmuRiz   Budget is key, I was going to keep my cis pistons ...   Jan 1 2023, 02:04 PM
930cabman   Thanks for posting, I am in the same boat, buildin...   Jan 2 2023, 04:03 PM
zfisher6164   thanks for the replies the CIS pistons are what I ...   Jan 2 2023, 11:53 PM
Superhawk996   thanks for the replies the CIS pistons are what I...   Jan 3 2023, 12:15 AM
brant   it should work with stock pistons.. and low compre...   Jan 3 2023, 12:33 PM
zfisher6164   I am reading the book and this was a 914-6 with a ...   Jan 3 2023, 12:54 PM
campbellcj   My 2.7 presently has Mahle cylinders w/ JE pistons...   Jan 3 2023, 02:48 PM
flyer86d   My 2.7 presently has Mahle cylinders w/ JE piston...   Jan 3 2023, 04:17 PM
pek771   Are these Nikasil or Alusil cylinders?   Jan 3 2023, 05:46 PM
rudedude   CIS with those pistons are most likely alusil. Th...   Jan 3 2023, 08:33 PM
targa72e   While the 2.7 RS pistons and Cylinder do not have ...   Jan 5 2023, 02:31 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:09 PM
