> 914-6 2.7 build...Piston type?, Pistons for a weber carbed 2.7 build
zfisher6164
post Dec 31 2022, 06:13 PM
Engine rebuild on a 2.7 weber carbed engine and the pistons used 8 years ago are fuel injected pistons and I have gotten a few opinions of the type of piston to use by none are
definitive. Any ideas?
thanks
zac
flyer86d
post Jan 1 2023, 11:55 AM
The engine that I built for my 1968 911 started out as a 1975 911S core. I used a set of 1973 Mahle 2.7 RS pistons and cylinders that I bought 30 years ago and never used and a set of 911L (911E) cams with Webers. Like your CIS pistons, the compression ratio is only 8.5-1 but they have enough valve relief to run 911S cams which the CIS pistons do not.
Today, there are other choices like using JE pistons in your stock nikasil jugs and higher compression ratios available. Have fun!
Charlie
zfisher6164   914-6 2.7 build...Piston type?   Dec 31 2022, 06:13 PM
sixnotfour   2.7 Mahle MFI.. only 8.5-1 thou or 2.9 mahle motor...   Dec 31 2022, 07:14 PM
zfisher6164   thanks the pistons in the engine now look like thi...   Dec 31 2022, 07:36 PM
zfisher6164   another picture   Dec 31 2022, 07:37 PM
Superhawk996   Pistons for the CIS fuel injection are not a great...   Dec 31 2022, 08:22 PM
zfisher6164   thanks this is the info I need the previous engine...   Dec 31 2022, 08:49 PM
zfisher6164   not sure about the cam but will find out soon   Dec 31 2022, 08:50 PM
flyer86d   The engine that I built for my 1968 911 started ou...   Jan 1 2023, 11:55 AM
brant   You really need a copy of the Bruce Anderson book ...   Jan 1 2023, 12:03 PM
JmuRiz   Budget is key, I was going to keep my cis pistons ...   Jan 1 2023, 02:04 PM
930cabman   Thanks for posting, I am in the same boat, buildin...   Jan 2 2023, 04:03 PM
zfisher6164   thanks for the replies the CIS pistons are what I ...   Jan 2 2023, 11:53 PM
Superhawk996   thanks for the replies the CIS pistons are what I...   Jan 3 2023, 12:15 AM
brant   it should work with stock pistons.. and low compre...   Jan 3 2023, 12:33 PM
zfisher6164   I am reading the book and this was a 914-6 with a ...   Jan 3 2023, 12:54 PM
campbellcj   My 2.7 presently has Mahle cylinders w/ JE pistons...   Jan 3 2023, 02:48 PM
flyer86d   My 2.7 presently has Mahle cylinders w/ JE piston...   Jan 3 2023, 04:17 PM
pek771   Are these Nikasil or Alusil cylinders?   Jan 3 2023, 05:46 PM
rudedude   CIS with those pistons are most likely alusil. Th...   Jan 3 2023, 08:33 PM
targa72e   While the 2.7 RS pistons and Cylinder do not have ...   Jan 5 2023, 02:31 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:07 PM
