| zfisher6164 |
Dec 31 2022, 06:13 PM
Newbie ![]() Group: Members Posts: 41 Joined: 19-January 19 From: California Member No.: 22,809 Region Association: None
Engine rebuild on a 2.7 weber carbed engine and the pistons used 8 years ago are fuel injected pistons and I have gotten a few opinions of the type of piston to use by none are
definitive. Any ideas? thanks zac |
| zfisher6164 |
Jan 2 2023, 11:53 PM
thanks for the replies the CIS pistons are what I found from a previous rebuild I am looking for a reliable street engine and was wondering if the nicki mahle piston and heads is needed.
| Superhawk996 |
Jan 3 2023, 12:15 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
thanks for the replies the CIS pistons are what I found from a previous rebuild I am looking for a reliable street engine and was wondering if the nicki mahle piston and heads is needed. There are other options Nickies (brand) cylinders / Mahle pistons are top of the line. Nickes are not exactly the same thing as OEM Nikasil. Nickies are CNC from billet as just one differentiator. However the OEM 2.7L Nikasil are great cylinders and were in existence long before there were Nickies (the brand) JE makes 90mm pistons that you should be able to use if your existing OEM Nikasil cylinders are in good shape. The 2.7l heads pose some challenges for an acceptable compression ratio perspective but I’d assume JE has that worked out with their dome and valve relief. I haven’t researched the 2.7l pistons much so I’m not an expert. I only know enough about 2.7s to be dangerous. Any info I know is from the Bruce Anderson book and what I found as I was going back and forth on 2.4l vs 2.7. I went 2.4l - part of that being that the 2.7l is somewhat unloved for a multitude of reasons one being the lack of clarity on good, affordable, buildable 2.7l variations. Keep digging. You’ve got homework to do! https://auto.jepistons.com/pistons-381250s |
zfisher6164 914-6 2.7 build...Piston type? Dec 31 2022, 06:13 PM
sixnotfour 2.7 Mahle MFI.. only 8.5-1 thou or 2.9 mahle motor... Dec 31 2022, 07:14 PM
zfisher6164 thanks the pistons in the engine now look like thi... Dec 31 2022, 07:36 PM
zfisher6164 another picture Dec 31 2022, 07:37 PM
Superhawk996 Pistons for the CIS fuel injection are not a great... Dec 31 2022, 08:22 PM
zfisher6164 thanks this is the info I need the previous engine... Dec 31 2022, 08:49 PM
zfisher6164 not sure about the cam but will find out soon Dec 31 2022, 08:50 PM
flyer86d The engine that I built for my 1968 911 started ou... Jan 1 2023, 11:55 AM
brant You really need a copy of the Bruce Anderson book
... Jan 1 2023, 12:03 PM
JmuRiz Budget is key, I was going to keep my cis pistons ... Jan 1 2023, 02:04 PM
930cabman Thanks for posting, I am in the same boat, buildin... Jan 2 2023, 04:03 PM
brant it should work with stock pistons.. and low compre... Jan 3 2023, 12:33 PM
zfisher6164 I am reading the book and this was a 914-6 with a ... Jan 3 2023, 12:54 PM
campbellcj My 2.7 presently has Mahle cylinders w/ JE pistons... Jan 3 2023, 02:48 PM
flyer86d
My 2.7 presently has Mahle cylinders w/ JE piston... Jan 3 2023, 04:17 PM
pek771 Are these Nikasil or Alusil cylinders? Jan 3 2023, 05:46 PM
rudedude CIS with those pistons are most likely alusil. Th... Jan 3 2023, 08:33 PM
targa72e While the 2.7 RS pistons and Cylinder do not have ... Jan 5 2023, 02:31 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:11 PM |
