| zfisher6164 |
Dec 31 2022, 06:13 PM
Newbie ![]() Group: Members Posts: 41 Joined: 19-January 19 From: California Member No.: 22,809 Region Association: None
Engine rebuild on a 2.7 weber carbed engine and the pistons used 8 years ago are fuel injected pistons and I have gotten a few opinions of the type of piston to use by none are
definitive. Any ideas? thanks zac |
| campbellcj |
Jan 3 2023, 02:48 PM
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,705 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California
My 2.7 presently has Mahle cylinders w/ JE pistons and DRC cams and that's worked out well. I wanted to upgrade to Mahle Motorsports pistons and get the C/R up around 12:1 vs 10.5:1 but that would've further blown my schedule and budget at the time, as the existing P&Cs were OK to reuse in the last rebuild.
| flyer86d |
Jan 3 2023, 04:17 PM
Member ![]() ![]() Group: Members Posts: 484 Joined: 12-January 11 From: Corea, Maine Member No.: 12,585 Region Association: North East States |
My 2.7 presently has Mahle cylinders w/ JE pistons and DRC cams and that's worked out well. I wanted to upgrade to Mahle Motorsports pistons and get the C/R up around 12:1 vs 10.5:1 but that would've further blown my schedule and budget at the time, as the existing P&Cs were OK to reuse in the last rebuild. That is good to know. Yours is a track car and it is holding up well. Charlie |
zfisher6164 914-6 2.7 build...Piston type? Dec 31 2022, 06:13 PM
sixnotfour 2.7 Mahle MFI.. only 8.5-1 thou or 2.9 mahle motor... Dec 31 2022, 07:14 PM
zfisher6164 thanks the pistons in the engine now look like thi... Dec 31 2022, 07:36 PM
zfisher6164 another picture Dec 31 2022, 07:37 PM
Superhawk996 Pistons for the CIS fuel injection are not a great... Dec 31 2022, 08:22 PM
zfisher6164 thanks this is the info I need the previous engine... Dec 31 2022, 08:49 PM
zfisher6164 not sure about the cam but will find out soon Dec 31 2022, 08:50 PM
flyer86d The engine that I built for my 1968 911 started ou... Jan 1 2023, 11:55 AM
brant You really need a copy of the Bruce Anderson book
... Jan 1 2023, 12:03 PM
JmuRiz Budget is key, I was going to keep my cis pistons ... Jan 1 2023, 02:04 PM
930cabman Thanks for posting, I am in the same boat, buildin... Jan 2 2023, 04:03 PM
zfisher6164 thanks for the replies the CIS pistons are what I ... Jan 2 2023, 11:53 PM
Superhawk996
thanks for the replies the CIS pistons are what I... Jan 3 2023, 12:15 AM
brant it should work with stock pistons.. and low compre... Jan 3 2023, 12:33 PM
zfisher6164 I am reading the book and this was a 914-6 with a ... Jan 3 2023, 12:54 PM
pek771 Are these Nikasil or Alusil cylinders? Jan 3 2023, 05:46 PM
rudedude CIS with those pistons are most likely alusil. Th... Jan 3 2023, 08:33 PM
targa72e While the 2.7 RS pistons and Cylinder do not have ... Jan 5 2023, 02:31 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:10 PM |
