> Plan of Action?, Bondo Floor?
stoneman30hotmail
post Sep 10 2022, 05:07 PM
Hello all, I'm a bit new to this. I had one of these in my 20's and and did a little stick welding fixing the hell hole.
I'm not sure how to approach this. Do I need to strip all this and go on rotisserie? Or is it feasible to cut and patch this from the top
The driver side floor is bondo (or something). I'm not sure what is holding the seat mounts. The passenger side seat mount right is about broken loose. There's also holes past the transverse strut into the battery area.
The longs seem ok from what I can see. Can I get the sill covers off without taking the fenders off? I was worried I drill out all the rivets to figure one hidden under the fender.
Any good tool recommendations for rust removal?
I was thinking maybe I can get away with with https://www.restoration-design.com/store/product/PP345BR and a https://www.restoration-design.com/store/PR...duct_Code=PP325 and the seat brakets and patch the holes.
Attached Image Attached Image Attached ImageAttached Image
Superhawk996
post Jan 2 2023, 01:05 AM
Your door braces are way to weak to be of any use in resisting the compression that occurs as welds shrink.
Do not proceed further. This needs to be fixed now before the structure gets even stiffer.
Step 1) Build proper door braces with tubing and heim joints.
Step 2) cut the long at the transition (see pic)
Step 3) regap the door
Step 4) reweld - go slow and cool as was suggested
stoneman30hotmail
post Jan 2 2023, 11:22 AM
QUOTE(Superhawk996 @ Jan 2 2023, 02:05 AM) *
Thanks, I'll try that.
bbrock
post Jan 2 2023, 12:23 PM
QUOTE(stoneman30hotmail @ Jan 2 2023, 10:22 AM) *
This is great advice. You can see in your photo that the turnbuckle wasn't able to withstand the shrink. I got by with iron pipe and turnbuckle braces but me turnbuckles were a little beefier than yours. I was also warned early about keeping the heat down by going slow with the welding. In the end, this little blip of a redo will be insignificant and well worth the time to get it right.
stoneman30hotmail
post Jan 3 2023, 04:42 PM
QUOTE(bbrock @ Jan 2 2023, 01:23 PM) *
Step 1. It popped back into place after the cut which also separated.
I think the issue wasn't so much the turnbuckle but rather where it was placed. It's all bent now because I really cranked on it in a last hope it could force the car apart. I think since I have the fender and wheel house cut out, the bottom has no brace to stop pulling in there. Ideally I'd have a brace going from behind the suspension console to the door frame but then I won't be able to close the door. Maybe weld in something temporary to reweld the cut as suggested by Dlee6205 and then go slow elsewhere. Like a tack weld every 2 min? Though I would think welding in the wheel house shouldn't shrink the door gap. I did get that AA part as well as the rear firewall and some hundred $ of other panels. ( I ended up with 2 passenger inner firewalls trying to get 5% on all the parts)
Also looks like the door frame pulled down I guess on welding in the rear firewall. So I'll try to undo the few spotwelds and see if that pops back up.
Superhawk996
post Jan 3 2023, 08:03 PM
QUOTE(stoneman30hotmail @ Jan 3 2023, 05:42 PM) *
The door brace is placed where it should be. It bent because it is too weak. It should have been able to influence that gap while in compression. That turnbuckle is designed for tensile loads only.
You don’t need a brace to the suspension console. It pulled the console inward due to shrink from welding too fast.
Look at tangerine racing door braces and approximate that. Tried and true. Trying to go cheap and/or too flimsy on the door bracing is penny wise, pound foolish.
stoneman30hotmail   Plan of Action?   Sep 10 2022, 05:07 PM
Superhawk996   Read these before you do anything. You have more ...   Sep 10 2022, 05:21 PM
SirAndy   You have more project on your hands than you think...   Sep 10 2022, 05:57 PM
bbrock   You have more project on your hands than you thin...   Sep 10 2022, 10:30 PM
Mikey914   If you choose to do this sure you have a brace in ...   Sep 10 2022, 06:10 PM
930cabman   Welcome aboard and it looks as though you are jump...   Sep 10 2022, 06:32 PM
mepstein   :wttc: The rust you see is always the tip of the ...   Sep 10 2022, 07:53 PM
bkrantz   Jump (gently) up and down on the right side and wa...   Sep 10 2022, 08:28 PM
Rand   Jump (gently) up and down on the right side and w...   Sep 20 2022, 08:13 PM
rjames   Sawzall, dremel, plasma cutter... sorry, being ...   Sep 10 2022, 10:29 PM
emerygt350   Just sayin guys, that barn find I took pictures of...   Sep 11 2022, 04:37 AM
stoneman30hotmail   Just sayin guys, that barn find I took pictures o...   Sep 11 2022, 08:24 AM
Cairo94507   :wttc: Don't rush. Take the time to read a lo...   Sep 11 2022, 06:42 AM
brant   10 years ago that was a parts car Nothing a few t...   Sep 11 2022, 06:59 AM
930cabman   10 years ago that was a parts car Nothing a few ...   Sep 11 2022, 08:03 AM
mepstein   Both cars need a lot of work. A lot of the Porsche...   Sep 11 2022, 09:47 AM
Superhawk996   Both cars need a lot of work. A lot of the Porsch...   Sep 11 2022, 10:08 AM
mepstein   Both cars need a lot of work. A lot of the Porsc...   Sep 11 2022, 10:21 AM
stoneman30hotmail   There’s just something to be said for the eter...   Sep 12 2022, 09:05 AM
Superhawk996   There’s just something to be said for the ete...   Sep 12 2022, 09:50 AM
nathanxnathan   I believe there's some rust on the inside of ...   Sep 12 2022, 12:30 PM
porschetub   [quote name='stoneman30hotmail' post='3028981' da...   Sep 12 2022, 10:57 PM
bbrock   There’s just something to be said for the ete...   Sep 12 2022, 01:40 PM
stoneman30hotmail   Get the chassis supported and secure, then spend...   Sep 12 2022, 03:17 PM
Wadesbrain   Ok so I think this sounds basic but it needs to be...   Sep 11 2022, 05:17 PM
930cabman   Ok so I think this sounds basic but it needs to b...   Sep 11 2022, 05:30 PM
SirAndy   Also check the "914 Info" at the top o...   Sep 11 2022, 06:00 PM
bbrock   Ok so I think this sounds basic but it needs to b...   Sep 11 2022, 09:46 PM
930cabman   [quote name='Wadesbrain' post='3028821' date='Sep...   Sep 12 2022, 12:27 PM
Superhawk996   There is no “zero” datum specified that I’m ...   Sep 11 2022, 06:03 PM
Eric_Shea   :agree:   Sep 11 2022, 06:39 PM
mepstein   Because fixing cosmetic issues would be a waste of...   Sep 12 2022, 09:19 AM
TRS63   I see it like the two previous poster..this car ha...   Sep 12 2022, 11:43 AM
friethmiller   Stoneman, You are most welcome to take a look at ...   Sep 12 2022, 02:05 PM
Wadesbrain   Stoneman, You are most welcome to take a look at...   Sep 14 2022, 08:20 PM
stoneman30hotmail   Stoneman, You are most welcome to take a look at...   Sep 21 2022, 05:41 PM
friethmiller   That does look like a nice way to handle it with...   Oct 27 2022, 07:50 AM
brant   many of us... have lived through the same senario....   Sep 12 2022, 02:52 PM
stoneman30hotmail   Wow guys, thanks for all the attention and referen...   Sep 18 2022, 05:47 PM
nathanxnathan   I've seen pictures where there is an inside p...   Sep 19 2022, 02:10 PM
bbrock   It's not going to be cheap or easy, you'r...   Sep 19 2022, 05:27 PM
bbrock   I believe the octagonal rotisserie is both a suppo...   Sep 18 2022, 06:25 PM
Cairo94507   Do it right or don't do it at all. The worst ...   Sep 19 2022, 04:18 PM
Superhawk996   Any pictures of what’s going on with the other s...   Sep 19 2022, 05:28 PM
stoneman30hotmail   Any pictures of what’s going on with the other ...   Sep 20 2022, 04:05 PM
rjames   Not a chance. :)   Sep 20 2022, 04:30 PM
stoneman30hotmail   Not a chance. :) Anybody tracked costs? I w...   Sep 20 2022, 06:20 PM
worn   Been there myself. My latest has taken two years ...   Sep 20 2022, 04:39 PM
mepstein   I don’t think you can restore a rusty car for ...   Sep 20 2022, 06:45 PM
Superhawk996   If you’re doing this to make money - you’re do...   Sep 20 2022, 07:47 PM
bbrock   We need to stop saying you can't restore these...   Sep 20 2022, 10:46 PM
Superhawk996   We don't consider our time costs for going f...   Sep 20 2022, 11:01 PM
930cabman   We don't consider our time costs for going ...   Sep 21 2022, 05:00 AM
brant   Bringing dollar signs into this discussion… ? ...   Sep 21 2022, 07:24 AM
mepstein   The "labor of love" will be different fo...   Sep 21 2022, 07:41 AM
Front yard mechanic   Set up a bunch of cameras run it off a tall cliff ...   Sep 21 2022, 07:43 AM
Superhawk996   Set up a bunch of cameras run it off a tall cliff...   Sep 21 2022, 08:29 AM
rhodyguy   Was this the first 914 you looked at? Does it even...   Sep 21 2022, 09:28 AM
bbrock   Like Mark said, only the owner can decide what to ...   Sep 21 2022, 09:36 AM
friethmiller   :agree: Yes!! Well said. My '74 LE ...   Sep 21 2022, 09:51 AM
stoneman30hotmail   Poking at this slowly. I cut away more so I could...   Oct 26 2022, 07:09 PM
bbrock   Is there something to do short of using a whole n...   Oct 27 2022, 04:34 PM
mepstein   Suspension console jig http://www.914world.com/bb...   Oct 27 2022, 10:28 AM
930cabman   Suspension console jig http://www.914world.com/b...   Oct 27 2022, 04:47 PM
DaveB   This is what I picked-up: I found too many sus...   Oct 27 2022, 12:32 PM
stoneman30hotmail   Exposed a bit more. So I'm wondering how...   Oct 29 2022, 11:35 AM
bbrock   So I'm wondering how much of this I can reuse...   Oct 29 2022, 04:03 PM
dlee6204   Exposed a bit more. Whatever I can haul off f...   Oct 29 2022, 12:58 PM
dlee6204   You are on a budget so you'll have to decide ...   Oct 29 2022, 04:06 PM
stoneman30hotmail   Thanks for the replies. Do you mean this stuff...   Nov 2 2022, 07:09 PM
bbrock   Do you mean this stuff for rust remove? https://...   Nov 2 2022, 10:44 PM
Superhawk996   This piece of sheet metal from Auto Atlanta is wha...   Nov 2 2022, 07:28 PM
stoneman30hotmail   This piece of sheet metal from Auto Atlanta is wh...   Nov 4 2022, 05:27 PM
Superhawk996   This piece of sheet metal from Auto Atlanta is w...   Nov 5 2022, 07:46 AM
stoneman30hotmail   I'm glad to see my thread made it through the ...   Jan 1 2023, 02:45 PM
Dlee6205   Looks like you lost 1/16"? Maybe a smidge mo...   Jan 1 2023, 06:14 PM
Geezer914   I would stop working on this car and look for a ca...   Jan 1 2023, 08:01 PM
stoneman30hotmail   I would stop working on this car and look for a c...   Jan 2 2023, 11:21 AM
rjames   If I was going to spend 30K on a car I would be ...   Jan 2 2023, 12:16 PM
76-914   Glad to see you navigated past the nay sayers. Des...   Jan 1 2023, 09:17 PM
Superhawk996   Your door braces are way to weak to be of any use ...   Jan 2 2023, 01:05 AM
stoneman30hotmail   Your door braces are way to weak to be of any use...   Jan 2 2023, 11:22 AM
bbrock   Your door braces are way to weak to be of any us...   Jan 2 2023, 12:23 PM
stoneman30hotmail   [quote name='stoneman30hotmail' post='3048791' da...   Jan 3 2023, 04:42 PM
Superhawk996   I think the issue wasn't so much the turnbu...   Jan 3 2023, 08:03 PM
Superhawk996   I would think welding in the wheel house shouldn...   Jan 3 2023, 08:18 PM
stoneman30hotmail   [quote name='stoneman30hotmail' post='3049028' da...   Jan 4 2023, 05:20 PM
bbrock   I think the issue wasn't so much the turnbuc...   Jan 4 2023, 08:55 AM
Superhawk996   I haven’t seen this thread in a while. Great jo...   Jan 2 2023, 01:23 AM
rhodyguy   Do not trust those ratchet style jack stands. DO N...   Jan 2 2023, 08:27 AM
Front yard mechanic   I think you got this :driving-girl:   Jan 3 2023, 05:51 PM
Superhawk996   I’ll apologise because my diagram is over simpli...   Jan 4 2023, 11:13 PM
jaredmcginness   Keep fighting the good fight! I think you are ...   Jan 6 2023, 06:43 AM
stoneman30hotmail   Keep fighting the good fight! I think you are...   Jan 10 2023, 07:23 PM
stoneman30hotmail   Time for some updates. I por-15 'd the insid...   Mar 30 2023, 06:18 PM
rjames   Time for some updates. I por-15 'd the insi...   Mar 31 2023, 10:36 AM
stoneman30hotmail   Time for some updates. I por-15 'd the ins...   Apr 3 2023, 03:47 PM
stoneman30hotmail   Someone said "don't trust the jack stands...   May 3 2023, 04:27 AM
mepstein   I would have made the base wider and triangulated ...   May 3 2023, 05:29 AM
Superhawk996   :agree: You’ve got a recipe for disaster brewi...   May 3 2023, 07:22 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:47 AM
