| bkrantz |
Jan 5 2023, 09:24 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,646 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
As I described in my build thread, last year, once I got the engine running, I noticed significant oil drops (or more) after each drive. With winter in full throttle, I decided to drop the motor, and see about fixing the leak.
Here's the view of the front. Maybe you can see some oil. Attached thumbnail(s) |
| bkrantz |
Jan 5 2023, 09:33 PM
No oil visible where I would expect it if the cooler seals leaked.
bkrantz Help me find my oil leak! Jan 5 2023, 09:24 PM
bkrantz I found some oil inside the inner blowing housing,... Jan 5 2023, 09:26 PM
bkrantz Starting from the top, the case seam looks OK. Jan 5 2023, 09:27 PM
Krieger
... Jan 7 2023, 08:29 PM
bkrantz The front seal looks a bit oil wet. But is the se... Jan 5 2023, 09:29 PM
bkrantz Lots of oil sitting on the top edge of the oil pum... Jan 5 2023, 09:30 PM
bkrantz Quite a bit of oil pooled in the right motor mount... Jan 5 2023, 09:31 PM
bkrantz Some oil sitting on top of the filter. Jan 5 2023, 09:34 PM
bkrantz Meanwhile, underneath I might have just a bit of o... Jan 5 2023, 09:36 PM
bkrantz But the inner seals, and the cylinder-to-case join... Jan 5 2023, 09:38 PM
Shivers Looking at that black wire on the front of the eng... Jan 6 2023, 08:00 AM
porschetub
Looking at that black wire on the front of the en... Jan 6 2023, 01:35 PM
dr914@autoatlanta.com you have an aftermarket oil pump, they are very ve... Jan 6 2023, 01:36 PM
930cabman
you have an aftermarket oil pump, they are very v... Jan 6 2023, 02:20 PM
Superhawk996
[quote name='dr914@autoatlanta.com' post='3049581... Jan 6 2023, 09:58 PM
930cabman
[quote name='dr914@autoatlanta.com' post='304958... Jan 7 2023, 06:38 AM
Superhawk996
I have wondered the same. Is this an application... Jan 7 2023, 09:44 AM
930cabman
I have wondered the same. Is this an applicatio... Jan 7 2023, 06:19 PM
bkrantz
I have wondered the same. Is this an applicatio... Jan 7 2023, 09:16 PM
Superhawk996
[quote name='Superhawk996' post='3049751' date='J... Jan 7 2023, 11:23 PM
bkrantz Thanks everyone. Based on what I see so far, I wi... Jan 6 2023, 09:54 PM
Superhawk996 I think you have oil going in the direction of the... Jan 7 2023, 11:50 PM
cassmcentee Is it possible to have a Wobble in the Crankshaft?... Jan 8 2023, 04:35 AM
Shivers
Is it possible to have a Wobble in the Crankshaft... Jan 8 2023, 07:08 AM
BeatNavy My two cents from my experience here: http://www.9... Jan 8 2023, 08:06 AM
Geezer914 If your oil pump cover was leaking, oil would be d... Jan 8 2023, 04:56 PM
bkrantz More thanks, everyone.
During assembly, I used a ... Jan 8 2023, 10:13 PM
searunner
As I described in my build thread, last year, onc... Jan 9 2023, 04:32 AM
bkrantz OK, more info. And in my quest for the right answ... Jan 9 2023, 08:12 PM
bkrantz I confirmed this by running a Qtip around the base... Jan 9 2023, 08:15 PM
bkrantz First stupid: when I went to unscrew the oil filte... Jan 9 2023, 08:21 PM
bkrantz No obvious leak point around the pump cover. Jan 9 2023, 08:22 PM
bkrantz No leaks around the studs. Jan 9 2023, 08:23 PM
bkrantz Here's the cover off. No dramatic scoring. A... Jan 9 2023, 08:25 PM
930cabman
Here's the cover off. No dramatic scoring. ... Jan 10 2023, 12:26 PM
bkrantz
Here's the cover off. No dramatic scoring. ... Jan 10 2023, 07:46 PM
bkrantz And the pump itself.
BTW, if I need to pull this,... Jan 9 2023, 08:26 PM
iankarr I have the same oil pump cover and it was farrrr f... Jan 9 2023, 08:50 PM
cassmcentee Great news!
Nothing crazy Jan 9 2023, 09:15 PM
bkrantz
Great news!
Nothing crazy
But perhaps prett... Jan 10 2023, 07:37 PM
r_towle Is there a slot in the body and cover for an o-rin... Jan 10 2023, 07:54 PM
bkrantz
Is there a slot in the body and cover for an o-ri... Jan 11 2023, 08:22 PM
nathanxnathan The fan tends to suck in and redistribute oil all ... Jan 11 2023, 11:44 PM
bkrantz Thanks, everyone. Going back to my build thread. Jan 14 2023, 09:26 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:06 PM |
